Help: would pay for a little script update or a new one !
Hello,
here is my problem: I'd like to import Ultrascenery scenes in Octane. I don't use the Octane bridge and it seems to have trouble with the scene complexity (but my hardware is also very old! )
Tofusan made a simple script available at ShareCG to create a CSV file from one DS4 instance node. The script works and generated CSV import well in Octane 2020.
I'd like to have 2 upgrades (or a complete new script) :
- a one click to export ALL instance nodes. Currently I must run the Tofusan script for each node and Ultrascenery can generate 60 nodes or more  ! The name of the CSV files could be the instance node names
- more complex: Ultrascenery generate some instance nodes for the same object (I understand a DS4 limitation concerning the number of instances in the same node) . To have one single CSV merging all instances nodes concerning the same object would be marvelous. This upgrade decrease the number of scatter nodes to manage in Octane
With this solution : an import in Octane would take less than 5 min for the first time (object and scatter nodes)  and less than 1 minutes for any update in DS4 (refresh of the scatter nodes only) of course with the same ecosystem
This script could also be used with Stonemason scenes , Ultrascatter, Ultratrees and in Octane we could do Ultrascenery scenes using Ultra trees ! ...
And yes: I could pay for that ! Anyone interested ?
Thanks !
PS : I contacted Tofusan but he don't use Octane anymore :-( !
Here is an old Octane scene I made with an HowieFarkes ecosystem.
