Field of Dreams
whispers65whispers65 Posts: 1,043
"If you build it, they will come." Well, I built it but no one will come because no one has anything to wear.
I did find this baseball uniform for M4, but it is all muscular and so forth and I'm not sure how or if I can change it. I looked for morph dials and so forth but not helping so far.
Any ideas? Or does anyone know of a better uniform to use? I've searched and scoured but to no avail so far.
Out of about 10 sports, I'm down to finding baseball uniforms for my project.
Thanks.
  • JaderailJaderail Posts: 0
    The muscle look is caused by the shape of the figure it is on, it conforms to the figures shape. To make it look less that way just use the figures Morphs Dials to change the body shape to what you would prefer the clothing to look more like. As much as possible anyway.
    Hope this helps some.
  • whispers65whispers65 Posts: 1,043
    Normally, ole Mighty One (and I mean that with a lot of respect), I'd agree but as you can see he is a pretty scrawny teen outside of the uniform. I put the uniform up beside him, not conformed to anything. And it looks like all of the muscularity is built into the uniform as opposed to conforming to the figure. Conforming to the figure is what I would like otherwise I'm going to have an entire group of teens look like they are on steroids.
    I also put the suit on another teen, even scrawnier than the first one and you can see he looks built now. So the suit seems to have a certain amount of bravado built into it, which I can't say that I've ever seen before or definitely didn't notice.
    1920 x 1080 - 991K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,646
    just an idea, can you fit it to m4, dial him down to a scrawnier or even up to a muscular size
    run transfer active morphs
    hide m4 export it as an obj no hidden
    then load it on the original as a morph target
    then you have a dial you can adjust, you can click the little gear icon and set negative values if using more muscular
    Hmm... well I did not have the Item and it just looked like the M4 shape to me. But it probably is modeled on the M4 shape and its built in. If you select the Uniform in the Scene Tab and then Open it in the Parameters Tab, set the parameters tab options to Show Hidden in the mini menu, see if you can Dial the built in M4 morphs down.
    That's all I can think to try without doing a full refit as Wendy suggests.
    Thanks to you both. I'll give it a try and see what I come up with.
