• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
JCM doesn't work in Blender!
acdum1857acdum1857 Posts: 105
December 2020 in Blender Discussion
I used the official bridge.
Changing poses in Daz changes the shape of the muscles, but not in Blender (&Maya).
I think it is because JCM doesn't work.
How can I fix it?
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,239
    December 2020
    Have you tried the Diffeomorphic plugin? It works better than the official bridge in just about every way. The JCMs work perfectly.
  • nicsttnicstt Posts: 11,715
    December 2020
    +1
  • acdum1857acdum1857 Posts: 105
    December 2020
     Yes, I have tried Diffeomorphic.
    The bridge didn't work only in the calf JCM, but Diffeomorphic didn't work in the whole body.
    You said in Diffeomorphic that JCM works perfectly, does it really work the same as Daz?
    After importing a character, whether Diffeomorphic or Bridge, do I need additional settings to make JCM work properly?
    December 2020
    Yes, you need to actually load the JCMs. I'm not at my computer right now, but the option on the N-Panel is pretty obvious once you know to look for it. I also remember that once, I had to set some option to allow Python to run, but interestingly, it only bit me one time.
  • jeff_someonejeff_someone Posts: 254
    December 2020
    Yes, there's a Load Standard JCMs in the Morphs panel on Diffeo. Also, not sure what the problem is on official DTB, all the JCMs work fine for me out of the box.
    December 2020
    Thank you for your answer.
    I ran 'Load Standard JCMs' in Diffeomorphic.
    Fortunately, the upper body JCMs worked, but still the calves and thighs did not.
    I am now having the same problem with both Bridge and Diffeomorphic, and I don't know what is causing it.
    A separate question, is there a way to load Subdivision 2 figures in Diffeomorphic?
    December 2020
    December 2020
    I think you just select the character mesh and add a Subdivision Surface modifier. The modifiers are on the tab on the right with the blue wrench. But I thought that if the character was subdivided, Diffeo would automatically add it for you.
    December 2020
    What character are you moving over to Blender?  Is it a standard Genesis 8 version character?
    December 2020
    It's a Victoria 8 model with morphs applied.
    In Diffeomorphic, only subdivision 1 or less is imported.
    So did the other models.
  • PadonePadone Posts: 4,019
    December 2020 edited December 2020
    Hi acdum. Both daz studio and blender get viewport and render subdivision levels, and diffeo correctly exports both of them. Then for the HD exporter the viewport subdivision is exported to HD, because the plugin needs to bake it from the viewport to correctly apply all the possible modifiers, especially the smoothing modifier.
    Then in daz studio you need to remove limits to get high subdivision levels in the viewport.
    Then you can export HD shapes but not HD morphs, including HD jcms, at least not to multires, because HD morphs are not supported by multires in the current blender 2.91 version.
    Post edited by Padone on December 2020
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
