Genesis 8 male "anatomical" figure
2»
  • SevrinSevrin Posts: 6,314
    nonesuch00 said:
    If you have a Pro Bundle already, just buy Jepe's Roderick character. Also RawArt's Maxx HD and PedroFurtado's Alistair have options. However, Jepe's Roderick has far and away the most options. More than you'll need I'm pretty sure but I think the way he designed the morphs pretty much eliminates you running out of unique combinations than a person could reasonable manage in a reasonable amount of time. You can even combine them with other products already mentioned.
    There may be other products too but I'm not sure. I've nowhere near close to checking all the morphs that get loaded for G8 when I load them, haven't even tried to use them all to check them and I'm not going to own every character in the store.
    I suppose that it's no coincidence that his name is Roderick.
  • miladyderyni_173d399f47 said:
    This reminded me of the Daz days of yore. My Michael 3 came with a genitals option. (Can't recall if M4 did as well.)
    The icon used was anatomically correct!
    The older males had anatomical elements in the body morph sets - the females got a genital crease mroph in the body morph pack.
  • GordigGordig Posts: 10,811
    Maxx is not a RawArt product.
    Yeah, fitting name. Is there a male given name that hasn't been turned into slang for toast? laugh
    My apologies. I've always gotten Soto (was Hellboy) & RawArt mixed up because I considered some of RawArt's monsters somewhat hellish I guess, don't know why I still mix them up.
  • Well, all that talking about anatomy made me check out how Mr. G8F was doing. But to my dismay he seems to suffer from some color problems regarding his private parts. Now this does not only happen to John G8F Doe but also to his relatives, be it Michael, Floyd or Diego to name a few. This color dilemma seems to be caused by the graft being a little bit off and not sitting right on top of the figure but a little bit moved to the inside so that the skin won't blend but show some bad irritations instead. As uninstalling and reinstalling those famous AE did not change a thing nor removing all those other morphs or UV maps from the data folder I guess that some recent install to the G8F genpool might have caused this color incontinence. Anybody else encountered something similar recently?
  • LeatherGryphonLeatherGryphon Posts: 12,503
    edited December 2020
    ColinFrench said:
    LeatherGryphon said:
    What ever happend to the DAZ tradition of calling the anatomical bits, "toast"?*
    * And how did that "toast" thing start, anyway?
    Maybe from "if you post an image of those on the forum, you're toast!"
    First time I've heard of that DAZ tradition, but it's amusing. laugh
    Well, "toast" is easier to say and spell than "anatomical bits" or the more medically and politically correct words. And avoids the stigma of the colloquial four letter words.
  • mr clammr clam Posts: 707
    I also like Jepe's Roderick morphs. I have 'tater male gens too, but they almost have too many parameters for me to deal with and the default settings look pretty odd. It's possible to make them look quite good, but it does take a lot of slider adjustments. Golden Palace is about 10,000 times better than the standard female gens from Daz.
    I wrote a ticket about that eons ago when I bought the Lucas 8 Pro Bundle and decided to test it discovering what you describe. Since then I've rendered so infrequently nudes that I've not noticed. I've rendered 3 nudes since then (Ezra, Dain & a 'skin material set' I made by combining 3 different DAZ 3D products with my own adjustments) & to hide the problem I just use the lots of body hair in the groin area. You can get rid of most of the effect by copying the torso shader settings. Some types of lighting really exaggerates the problem too.
