Iray Stand Kit - 2 issues
1. The Iray Stand Kit renders with CPU instead of GPU, at least on my computer.
2. The Iray Stand Kit ignores the Post Denoiser buttons (making renders grainy),
None of the above changes, if i delete the Stand Kit components in the scene. I have to restart Daz Studio fo fix this.
  • 2. is a consequence of 1. 1. may be the result of a known issue - try turning on end caps in the Section Objects group in the editor tab of Render Settings.
  • reserv888reserv888 Posts: 1,164
    Thanks Richard!
    Tested. No improvement.
    Thanks Richard!
    Did you restart DS?
  • fastbike1fastbike1 Posts: 4,083
    @reserv888 "None of the above changes, if i delete the Stand Kit components in the scene"
    That would imply that your original scene is the issue. Too big for VRAM, thus dropping to CPU, grainy rendes from not enough light / time.
