Adding to Cart…
1 of 46 purchased products :
Today 1 of 11 updates :
Is DIM still available for download?
https://www.daz3d.com/install-manager-info
You can do a manual installation if you want to keep the DazConnect structure (1 product = 1 folder)
August 8, 10 of 24 updates :
August 13, 7 of 10 updates
August 15, 1 of 1 update
August 17, 2 of 3 updates
August 19, 3 of 6 updates
August 23, 2 of 2 updates
New computer, new download, new install but these products are still unusable.
Oct. 25
Oct. 26
Oct. 31
5 months later, I found 59 corrupted products.
and reported them? Only posting here will not help.
But it would be better if other people could confirm that these products are broken before reporting something wrong.
I just recently started another thread with this very same problem. I first thought it was my system problem but after further experimentation I found it is Daz Connent screwing up all new dowloads. All files take forever to DL and never complete. They all have .part at the end and can't be catagorized because there are no legit files completed. Maybe this will get fixed when Daz updates servers today?
DIM works fine and can be catagorized no problem.
Ticket is open !
Connect is still, mostly, working for me - I even tried one or two of last night's downloads without getting any errors.
I think the offline method breaks the metadata, SEP/SEA files aren't reliable but it worked for 99% of my library.
60 items are only 1% of my library.
While they fix the store update, more new purchases can't be used.
Finally I decide to install the corrupted files and replace them by those from the DIM packages. Daz Studio doesn't see the difference.
This way let me keep the Daz Connect folder tree without installing the useless Poser files from DIM.
Another corrupted product : 78724 dForce Niko Outfit for Genesis 8 Males
A ton of PART files with 0 byte and 0 files in the product in Daz Studio
Only DIM can install this product.
Again a ton of PART files with 0 byte and 0 files in the product for
And the usual corrupted files for :
Special character causing troubles
2020-11-28 00:09:32.053 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_55419\runtime/support/daz_3d_55419_the_king?s_son_hd_for_genesis_8_male.jpg.part"
2020-11-28 00:09:32.084 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_55419\runtime/support/daz_3d_55419_the_king?s_son_hd_for_genesis_8_male.dsx.part"
2020-11-28 00:09:32.084 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_55419\runtime/support/daz_3d_55419_the_king?s_son_hd_for_genesis_8_male.dsa.part"
2020-11-28 00:09:34.305 "The King’s Son HD for Genesis 8 Male": Install Failed.
400 Bad Request for 41 Food Shaders (10 of 10) in Daz Connect -- Fixed
2020-11-29 14:13:54.663 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/42/78942/enc/66cc7638afa97b3f263a48013ee48882_4a2a76.enc) failed: Transferred a partial file
2020-11-29 14:13:54.663 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to download output file "C:/Data/3D/DAZ/Connect\data\cloud\1_78942\runtime/textures/those things/food shaders/fs broccoli normal 4k.png.part"
2020-11-29 14:13:57.086 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/42/78942/enc/e0efdd80fb0a15e3d9975bc4673eb697_5d41d4.enc) failed: Transferred a partial file
2020-11-29 14:13:57.086 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to download output file "C:/Data/3D/DAZ/Connect\data\cloud\1_78942\runtime/textures/those things/food shaders/fs swiss cheese normal 4k.png.part"
2020-11-29 14:14:10.639 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/42/78942/enc/b6ae0e0a9dd856eadc9b71d78c7f6d68_482454.enc) failed: Transferred a partial file
2020-11-29 14:14:10.639 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to download output file "C:/Data/3D/DAZ/Connect\data\cloud\1_78942\runtime/textures/those things/food shaders/fs broccoli normal 2k.png.part"
2020-11-29 14:14:22.120 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/42/78942/enc/01d0ce2aace1950d4af1dfa17d6784f3_8c41f0.enc) failed: Transferred a partial file
2020-11-29 14:14:22.120 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to download output file "C:/Data/3D/DAZ/Connect\data\cloud\1_78942\runtime/textures/those things/food shaders/fs raw meat normal 4k.png.part"
2020-11-29 14:14:22.140 "41 Food Shaders (10 of 10)": Update Failed.
30280 SolidGear bodysuits for M4, no install error but 126 files are missing (42 pz2 Material presets)
These files don't upload through Daz Connect for me. They take a long time to load and then you find that they won't work because some of them are only part files. (I waited an hour and a half for one of them only to find I wasted my time.) Is there a way to cancel the download through Connect if it is taking too long? Only way I know is to close DS.
dForce Evergreens Outfit for G8 Males
dforce Niko Outfit for G8 Males
Millenium Puppy
Reflections Furniture
dFore Evening Dress for G8 Males.
There are probly others. These are just the ones that show updates available in DS.
How do you locate the others?
Thanks.
I click the "Work Offline" button if I want to cancel current DAZ Connect download queue.
The others have no thumbnail for the items or have a failure message in the log file ( Help -> Troubleshooting -> View log file... ).
If it's just one product, and you want to give others a chance without tracking them down again (given the bad ordering by order date) you can right-click on the icon and select Cancel Operation.
Thanks, I'll try that!
Daz Connect 400 Bad Request for :
Connect has been brutally slow all day, even for small files.
72471 Graphic Brows Look for Genesis 8 Female(s) is corrupted
using an SSD or a HDD? and if an SSD how old is it?
