how do I fix this? Solved
RitaCelesteRitaCeleste Posts: 625
edited June 2014 in New Users
How can I fix this? I have reinstalled and I can't stop the bubbles from appearing. They don't appear in renders but I want them gone.
Post edited by RitaCeleste on
  • RitaCelesteRitaCeleste Posts: 625
    edited June 2014
    they are surface zones on the dress. I turned to opacity off. they don't show up but was this dress suppose to have materials zones? Its the dress from fantasy separates vol 3. It has two materials zones that work and then names for zones that are only bubbles.
  • scorpioscorpio Posts: 8,534
    I think you will find that the bubble are handles to help movement.
    edited June 2014
    Yes they are handles and (in poser anyway) each has also a name (first image) which you can use to pose the dress
    It has quite a few material zones, which show in the Poser mat room like this. (2nd image)
    TO get rid of them you should make them invisible (zero opacity or 100% transparetn) the highlighted ones
    196 x 280 - 46K
    173 x 471 - 65K
    Post edited by Chohole on
    edited June 2014
    Now that is interesting. I don't think I have that poser only dress installed any more, yet I had come across it, and it had cubes just like your bubbles (Bright obnoxious colors, and hovering in mid air all around the thing) . I'll need to look at that again, tho I remember the cubes showing up in a test render, ant tossed it then and there.
    (edit)
    Yep, That blue Pleated Skirt, for A4.
    "Traditional sailor uniform for A4"
    Software: Poser8 or later
    note:Not tested D|S and Mac.
    I don't have A4, nor Poser. Never mind, it's good to know tho.
    Thanks, I'll stop trying to hide them now, lol. Since I'll need to be able to find them and all. :D I couldn't figure it out, I didn't find them until I messed with the surfaces.
