Do you recognize this sword?
Seeker Stock Art
Do any of you, by chance, know what asset this sword is from? I'm trying to track it down for a client project. Thanks! I've looked through literally every fantasy outfit and every weapons set asset in the Daz store with no luck, but the search functionality in the Daz store has been wonky for me since the big site update, so I don't trust its results.
I was unable to find it, but I'm going to tell you what I did in case you want to try some of these sources and not duplicate my efforts. I'm no sword expert but I do look for enough of them that I thought I might've seen it before, so I tried.
1) I searched my own collection. And yes, I know you couldn't duplicate that part if you wanted to :)
2) I searched for "sword" at renderosity. It didn't turn up in those results.
3) I searched for "sword" at 3dcu, which only returns 100 products maximum. It didn't turn up that way.
4) I searched for "sword" at forender.com. It didn't turn up there although they do have very similar styles.
5) I searched for "sword" at cgtrader, including both the "free" and default ("not free") searches. At 120 results per page, I checked all 8 pages of free results and the first ten (of at least 55) pages of not-free results, with the default sorting parameters. It didn't turn up there.
Keep in mind, that doesn't mean it's not on any of those sites; it might be available at any of them, just not in a way that would cause it to turn up in a search for that term.
Also keep in mind, it could be an "omni"-type prop from renderosity, which are designed to morph in a million ways. I kind of don't think so though because none of the cross-guards (between the handle and the blade) seemed to morph in a way so as to produce "yours."
Also keep in mind, it could be a prop generated in any other non-compatible software like 3DS Max, but converted to an .obj file and imported into DAZ Studio if that's the source of your image.
I hope someone else is able to ID it though. Best of luck!
I really appreciate you having a look! I'm baffled at how hard this blade is to find. I almost wonder if it's a custom design by the Daz designer herself. I don't know if she has that skill, but I'm starting to wonder if that's why I can't seem to find it anywhere. Thanks again!
