Ideal Beauty for Genesis 2 and V6 Manual Download not working
My InstallManager is not working. So I decided to do a manual download. I extracted everything to ...Daz3D/Studio/My Library, but the product would not show up. None of the dials showed up on the Shaping tab.
Please Help!
Are you sure that Genesis is in 'My Library'?
If you installed Genesis using the default folder that DIM uses, it would have been put into a folder called 'My DAZ 3D Library'
I do not own this product, but the product description says that these morphs are applied automatically and work in the background. So maybe there are do dials for shaping. (Just guessing)
The top folder of these .zip downloads is a /Content/ folder. Did you extract that as well into your /My Library/ folder? If you did, then D|S can't see it; you've put a content folder into another content folder. Check your /My Library/ folder — in an Explorer window, not in D|S — and if you have this extra Content folder, move its contents up one level to the My Library folder, they should merge with the content files you already have.
This goes for all manual .zip downloads — you do not extract the Content folder, you extract the contents of the Content folder. It might seem like a small difference, but it's a vital one. D|S can only find your content files if you install them properly.
Yes, I did that. I even extracted the files to My DAZ 3D Library. Nothing's working. I just want the dials to show up :(
This might be the problem — if I'm reading the file list properly, the master morph controls are in the Shaping folder in the Genesis 2 Female folder in the Content Library tab. The matching master control dials ought to be in the Shaping tab, but that is not 100% reliable, try looking in the Parameter tab. Dials not appearing in the Shaping tab is an occasional known problem that can be fixed, but it has to be reported as a bug first.
Fortunatelly I already bought this product.
if you installed them corectly,
master key (ideal beauty) property are located,
in parameter tab
Actor>Full Body>Real world>ideal beauty>ideal beauty.
Then,, in Contet Library, you will find 4 scripts.dsa files.
(see my pic,,)
at first,, apply "Ideal beauty.dsa".
it auto turn master key "ideal vieuty" value "100%"
of course without apply script, you can manually change value of master key too)
after that many jcm works as hidden property when you bend or rotate each body parts.
then if you hope to tweak each body part efefct,, as dial,
apply IB advanced.dsa.
after that they will be shown in parameter tab,
when you select root genesis2female.
Actor>Full Body>Real world>ideal beauty.
( these properties are set as hidden property. then when apply scirpt they turn visible)
then I think,, why vendor not set type as modifier/shape,(to be shown them in shaping tab)
these shape morph are desigend to work when pozing ,, it seems difficult to categorize,(poze or shape):)
Thanks! It works now!!! I would give you a cookie if I had one :)
