Dictionary Help Please
2»
  • SzarkSzark Posts: 10,634
    Cool.
    Ok Surfaces yes that makes it a little harder as we have the DS (Daz Studio) default surfaces explained here http://homepage.eircom.net/~neilvpose/ds-settings.htm and the new Subsurface Scattering Shader that now comes with the newer figure skin texture sets. Then on top of that we also have a shader called Uber Surface which a number of new but older skin sets have. My advice is to go through that tutorial I linked to first and get an understanding of the default surface then you can move on to the more Advanced SSS shaders.
    Also give yourself time to learn all this.
  • srieschsriesch Posts: 4,243
    Let's start with your two specific issues.
    (although I'm really good at throwing rocks too, so here's a few to start with:
    The most basic parameter would be the Diffuse Color. For the moment, just think of that as the object's color. normally it will be either a solid color with no image texture, or an image texture along with the color white (which won't affect the image texture). If you use both an image texture AND a color, it will add a tint to that texture; you probably don't want to do that normally, although it could be handy sometimes
    Ambient Color: this will make things unnaturally brighter. Handy for special effects, or for cheating, but it'll screw up your shadows, so you usually don't want it.
    Opacity Strength: Used to make pieces of your object transparent.)
  • laststandlaststand Posts: 866
    Szark said:
    Cool.
    Well Szark, I took a look at your gallery, and all I can say is, wo [brow up].
    I'm going to go over that tutorial you linked to above, and then I'll comment.
    More later.
    I'm starting out with the blurb Szark suggested. Since I know zip now, I can't help but learn from it.
    As a coworker used to say, I am "expanding my sphere of ignorance."
  • JaderailJaderail Posts: 0
    I strongly suggest you Download and read the DAZ Studio Quick Start guide and Users guide PDF's. One of the two, my issue is I forget which, covers the Surfaces Tab and all its functions very well in language beginners should get with no trouble. Here is a link...
    http://www.daz3d.com/forums/discussion/32249/
    This is a little bit embarrassing, Jaderail. While looking at Niel V's tutorial, I happened to open the DS manual. What do you think I found? Chapter 3, p37, titled [drumroll] Textures, Surfaces and Materials. Yeah, I felt stupid. Maybe I will be able to compose a more intelligent question now. Damn.
    Thanks.
    Yeah I forget about the new manual with not having one for so long. ;)
    Thanks for the Gallery comment. If you pop over to my Render Thread you will find some interesting tutorials listed on page one, post one.
    I've come up empty handed a dozen times, keyword searching the DS Manual. It figures that when I don't look in there at all, the exact thing I need has its own chapter.
    Yes, I had a look at your render thread. Maybe I'll comment there.
    596 x 621 - 28K
