Show Us Your Bryce Renders Part 11
1…5354565859…100
  • mermaid010mermaid010 Posts: 6,292
    Rieke - thanks
    Horo - outstanding renders with the artifacts, awesome anaglyph
  • HoroHoro Posts: 11,726
    adbc and mermaid - thank you.
  • Rieke77Rieke77 Posts: 619
    @ Horo - your artifacts renders are awesome.
    Thank you Rieke77.
  • adbcadbc Posts: 3,115
    edited November 2020
    An abstract using Mat Creator's "space bug", and HDRI, a plane (mirror) and the EWL.
    450 x 600 - 55K
    Post edited by adbc on
    Adbc – very nice abstract, I love the colors
    Another landscape using David and Horo’s High-Res set 4.
    875 x 492 - 502K
    Post edited by mermaid010 on
    adbc - this space bug looks great.
    mermaid - very nicely done scene, the water looks very good.
    mermaid, horo : thank you.
    mermaid : beautiful scene, the water with a bit of foam reaching the land is very well done, I like the atmosphere.
    Thanks Horo and Adbc for the nice comments
  • HansmarHansmar Posts: 3,230
    Horo: Again a great view of the alien artefact.
    Adbc: That space bug really looks amazing in your render.
    Mermaid010: Very good landscaping and great sea. The boat looks to get into trouble, though coming too close to the rocks.
    Two new landscapes. Though both are sunset/sunrise type renders, I decided to enter neither of them in the contest.
    The green one has a stacked terrain. The second terrain creates the small rocks all over the terrain. The yellow one I call 'twilight at Wadi Rum', though it does not really look like Wadi Rum, I think.
    Both terrains are made with a combination of TE-filters and modifications at the terrain editor.
    1754 x 875 - 1M
    1754 x 875 - 1M
    Post edited by Hansmar on
    Hansmar : thank you.
    The green terrain with the rocks is very cool.
    I think the sand at Wadi Rum looks a bit different, anyway it's a nice image.
    Hansmar - thank you. Very nice terrain work, both look great.
    I converted a couple of HDRI angular maps David and I had made for sets some of them Daz accepted and some declined to terrains, which kept me busy for a while. This terrain was made with Gasclouds_B01 and the HDRI is also used as sky and ambient light. A cone with a streaming light effect (from the Inclement Weather set) grossly modified to shine from the sun at left.
    Stony land
    1200 x 780 - 257K
    Post edited by Horo on
    Horo : awesome image, great sky and terrain.
    Hansmar - thanks for the comment, the sailor is a good navigator wink, both your landscape are superb.
    Horo - beautiful landscape the sky and rays are awesome
    This terrain was made with Gasclouds_B02 and the HDRI is also used as sky and ambient light. The haze is a cube (from the Inclement Weather set, the haze horizon line was too high to use haze).
    Impact Site
    1200 x 800 - 174K
    Horo - Wow beautiful render.
    Horo : Awesome render, beautiful lighting.
    Based on a terrain, posted before,  two images with a bit of manipulation.
    900 x 450 - 77K
    900 x 450 - 86K
    Post edited by Chohole on
    Adbc - both your renders are awesome, I like the reflections in the 1st one.
    adbc - thank you. Two excellent renders. They are different but nevertheless similar. I like the colour and contrast of the first, and on the second I like what looks to me like alien cities. The sky is great.
    This terrain was made with Gasclouds_B03 (from Landscapes under Fantastic Skies) and the HDRI is also used as sky and ambient light.
    Sheer Mountains
    1200 x 780 - 183K
    Horo - another superb render, beautifully done.
    mermaid, Horo : thank you.
    Horo : awesome result with the gassclouds terrain.
    mermaid and adbc - thank you. I've converted 20 HDRIs to terrains ...
  • spuddyspuddy Posts: 449
    Wow so much to comment on all I can say is they are all wonderful and very interesting
    I have been experimenting a bit
    1080 x 704 - 1M
    1754 x 875 - 2M
    Post edited by spuddy on
    Horo, adbc: wonderful terrain work and well rendered.
    Spuddy: the  first render has a very nice background Is that a background or did you make that yourself. The car looks a bit weird. Maybe I am used to more shiny cars (though mine is not)?  The sky in the second one is very nice. It is almost a pity that the view of the sky is not complete, because of the buildings.
    spuddy :  I do agree with Hansmar's comments.
    Horo : just curious, how did you convert those HDRI's. I suppose PaintShop Pro can do the job.
    spuddy - two nice renders. On the first, I think the car needs some work: windws transparent, car body reflecting. The second is very nice with a great sky.
    adbc - it's a bit tricky. I used the angular maps that I had to remap into the spherical projection. I used HDRShop for this because it can do n x n supersampling along with bilinear interpolation, but Bryce can also convert an angular map into the spherical projection. Then I rescaled the 2:1 spherical projection to square in Photoshop, set saturation to 0 (remove colours), set it to 32-bit grey scale and then reduced to 16-bit, adjusting the brightness. Finally I optimised the contrast with TE-Filters so the lowest/darkest part is at zero and the brightest/highest at 65,536.
    Spuddy - two nice renders I love the sky in the second one.
    Horo - thanks for the explanation, I was going to ask the same question
    Wow, so many awesome images.  yes
    I like them all and you all inspired me
    Horo : thanks for the explanation, quite complicated, I just tried something else.
    For both images I used gasclouds B03 1280, the first one has a Bryce sky, the second one a sky from Landscapes under fantastic skies.
    For the first image I changed the HDRI into Latitude/Longitude with HDR shop free, to get rid of the circle with black background, the result is not too bad but I used two terrains. For the second render I changed the HDRI into a mirror ball close up, which gave me a square image, I think that the result is a bit better and there is only one terrain.I converted both  into greyscale with paintshop pro, decreased the colour depth, adjusted the brightness and contrast.
    I would call them : crazy terrains.
    750 x 487 - 48K
    740 x 440 - 54K
