Why does this happen?
Upirium
Sometimes when I go to INJ (usually) a body morph into V4, it gives me these errors like it's looking for something, but its looking for things that aren't for V4. Like things for Aiko and The Girl figures.
And I'm making sure I'm clicking the right INJ. So why does it do this?
A4 and Girl4 are morphs for V4.. Some characters may require these morphs to work as designed, although they may work acceptable without them.
Like Mike said in most cases the inj file is referencing a morph file that it needs to complete the shape. Its possible that the creator of the inj used a combination of Aiko 4, Girl 4 etc. to create the character.
However, sometimes the creator of the INJ file did NOT use those morphs to create the character, but still left references to those files there. Basically the reference says set Aiko 4 to 0 or set Girl 4 to 0. Obviously you don't need the Girl 4 or Aiko 4, but you still get a missing file message because it is looking for that morph to set it to 0. This is generally considered a bug in the product.
The way you can tell the difference is how your figure looks after loading the INJ file. If it looks messed up and not at all like it is supposed to, then it probably requires whatever file was missing. If it looks just fine then you can disregard the missing file error.
If the INJ file was part of a product you purchased from us then check the product page. It will have a list of required products. If you have further questions you can contact Technical support and they can help you out. If it is a bug they can report it to QA.
