Annoying UI problem: Stuck tab panes
RiggswolfeRiggswolfe Posts: 916
This has happened to me once before. Sometimes my tab groups get 'stuck' extended out which narrows my preview area to being almost useless. In both cases I didn't mouse drag it out and attempting to mouse drag it back does nothing. I've included a screenshot and in this case it is the content area on the right that is the problem.
Post edited by Riggswolfe on
  • fixmypcmikefixmypcmike Posts: 19,741
    Do you mean clicking the collapse arrow isn't working? What does it say in Help > Troubleshooting > About your video card?
    600 x 372 - 49K
  • RiggswolfeRiggswolfe Posts: 916
    The collapse arrow works. But I like to leave the pane open while I'm working to quickly select different parameters and objects in the scene. What I mean is see how far it is sticking out? Normally it's much smaller but I can't drag it back into place, it stays that size. So I can either collapse it or deal with it which is making working in the scene a pain, especially if I want to select something from smart content, then tweak it in parameters, such as adding a figure or pose.
    Have you added any other panes to that side? Some panes have a minimum width, and the widest pane determines the minimum width for each dock area.
    That was it. I noticed a tab at the bottom called Tool Settings that I don't remember adding. I removed it and was able to shrink the panel. I must have somehow hit a specific key combination or something and made it appear!
