Kimba, the white lion
I'm trying to create an adult Kimba, the white lion. Any ideas of how to get him all white? I tried the iRay Ghost Shaders, but it's neither transparent enough nor white enough. Please help!
Thanks,
Frank
Thanks,
Frank
Thanks,
Frank
Couldn't you just go to the base color in the surface tab and change it to white? I've changed people's skins to all sorts of colors that way before.
For example in the Feldae lion, I went to the texture and make a copy, then turn it black & white, then in the surfaces select the B&W jpeg. Lather rise repeat with all the surfaces until you have what you want.
There's this
https://hivewire3d.com/cwrw-white-lion-for-the-hivewire-lion-family.html
I've done this in Poser and don't know if it will work in DS. I was trying to get some angel wings truly pristine white but it wasn't working. Then I found that one of the lights was a fleshtone. Turning that white helped but all the people's skin looked washed out. I finally hit on adding white to the ammbient or reflective channel. You have to be careful though because it can give a gloew in the dark effect.
