Kimba, the white lion
I'm trying to create an adult Kimba, the white lion. Any ideas of how to get him all white? I tried the iRay Ghost Shaders, but it's neither transparent enough nor white enough. Please help!
Thanks,
Frank
  • I'm trying to create an adult Kimba, the white lion. Any ideas of how to get him all white? I tried the iRay Ghost Shaders, but it's neither transparent enough nor white enough. Please help!
    Thanks,
    Frank
  • Couldn't you just go to the base color in the surface tab and change it to white? I've changed people's skins to all sorts of colors that way before.
  • TBorNotTBorNot Posts: 380
    For example in the Feldae lion, I went to the texture and make a copy, then turn it black & white, then in the surfaces select the B&W jpeg.  Lather rise repeat with all the surfaces until you have what you want.
    1161 x 767 - 253K
    1024 x 1024 - 686K
  • pwiecekpwiecek Posts: 1,598
    I've done this in Poser and don't know if it will work in DS. I was trying to get some angel wings truly pristine white but it wasn't working. Then I found that one of the lights was a fleshtone. Turning that white helped but all the people's skin looked washed out. I finally hit on adding white to the ammbient or reflective channel. You have to be careful though because it can give a gloew in the dark effect.
