Boho Cottage Bedroom Bump Map Missing
I hope this is the right place to put this, I purchased the all the Boho Cottage and all is well except the Bump Map for the globe in the bedroom set is missing, Can this be fixed please.
  • NorthOf45NorthOf45 Posts: 5,898
    Is it throwing an error? That would require a help ticket to get an official correction.
    Does it actually load into the bump channel, or is it blank? Sometimes there is a reference in error, but does still work properly. You could add it manually if the file is in fact present in the product to continue with your work.
  • SevrinSevrin Posts: 6,314
    Put in a ticket for technical support.
