shader tutorials
dot_batdot_bat Posts: 373
edited June 2014 in Carrara Discussion
can anyone point me to any shader tuts ie distressed shaders weathered
and worn? thanx
Post edited by dot_bat on
    edited June 2014
    have you seen http://www.digitalcarversguild.com/plugin.php?ProductId=17 ?
    or http://carraracafe.com/tutorials/grunge-blood-textures-in-carrara-i/
    or simple tut:
    in carrara you can use the operator thing in the shader room
    in colour parameter choose operator> mixer
    then choose two textures in the tree below that (textures of your choice)in the blender area put in a grunge texture of your choice
    so the top texture might be shiny metal
    the bottom texture a rusty metal
    the grunge texture will mix the two according to the amount of black or white in the texture
    altearnatively you could choose operator>add or multiply
    and mix the eg shinty metal texture with a rust texture using that method
    plenty of grunge textures on the net but you can paint your own for more control
    eg
    http://www.smashingmagazine.com/2008/10/28/40-beautiful-grunge-photoshop-tutorials/
    Post edited by Headwax on
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    edited June 2014
    and worn? thanx
    I do recommend you this tutorial: Hard surface texture painting
    In Carrara, you can use elevation or slope (or even snow) shaders as mixer.
    If you happen to own baker plugin, you can generate an occlusion map as in this tutorial.
    For scratches, there are a lot of photoshop brushes that can be easily converted to Carrara D paint brushes.
    Post edited by Philemo_Carrara on
    Holly at the Carrara Cafe has been gathering and organizing all the Carrara tutorials she can get a hold of. You may find some there.
  • dot_batdot_bat Posts: 373
    thank you all for the info, have my work cut out for me this weekend
