in-scene tailor's chalk
mCasualmCasual Posts: 4,607
edited November 2014 in Freebies
apparently i made 2 threads for this one, sorry !
http://www.daz3d.com/forums/discussion/44077/
( the pose and image composition is inspired by "Care to join me for a dip" render in the June contest entries from last year )
http://www.daz3d.com/forums/discussion/41978/
see in Figure 1 the blue plane and the green plane?
just regular primitive planes
the black fabric is the bottom section of the mcjA3Maillot for Aiko3
http://www.daz3d.com/forums/discussion/5731/
you select the hip node of the maillot
you select the green plane
run a special script
and 2 seconds later you have on your disk an image like figure 2
each point is the location on the texture map of where the green plane cuts through a facet of the maillot
repeating this for the blue plane and the buttocks of the maillot
we get all we needed to build a transparency map like fig 3
which we apply to the opacity channel of the maillot and we get a bikini bottom which is not all warped wrong by the poser-rig !
Post edited by mCasual on
  • StratDragonStratDragon Posts: 3,279
    so if M4 needs a pair of "man-pris" I just do this? Cool!
  • Miss BMiss B Posts: 3,071
    So in essence, you made a bikini bottom out of a pair of shorts? Nifty.
  • mCasualmCasual Posts: 4,607
    it should also be a big help when making ''body-paint'' things like stalkings
    ( it's somewhat related to the 3d-painting plugin i may do someday )
    3d-painting plugin? Oh now you've got my full attention. ~LOL~
    edited June 2014
    ( also the word i meant was stockings )
    a while ago i did mention 3d painting i forget if i posted a script ... searching ... in my test i applied a tattoo on Amy i think
    found it ! it was "decals" http://www.daz3d.com/forums/discussion/24838/
    last summer
    but apparently i didnt make my script humanly usable enough to post it
    another backburner project ... which i didnt totally forget about !
    1280 x 720 - 148K
    386 x 500 - 19K
    Yes, just read that other thread. Keeping my eye on that as well. :coolsmirk:
