DAZ Studio communication to server failed
Start DS as normal. The wecome screen where it connects to my account says:
Communication to server failed.
This is a new problem, I did not have this error before the server change.
My email and Pass are correct.
  • I'm having a similar issue. but its not accepting my credentials
  • I'm also having these problems. "Communication to server failed."
  • I'm also having this problem. I have Daz on my Mac, but I'm still using OS X Sierra.
  • JVRendererJVRenderer Posts: 664
    edited November 2020
    I just use DS in offline mode. I manually installed 99% of my content and avoid DazConnect like the plague,
    Post edited by JVRenderer on
  • People have been reporting issues logging in, mainly with DIM/Daz central but it would not be altogether surprising if Connect was affected (though I don't believe they use the same servers).
  • I have also been having this problem for roughy the same time period... I'm on Mac Sierra as well... any solutions?
  • ChakradudeChakradude Posts: 285
    I have the same issue. I just decided to get my mac going again for daz renders. I am on el capitan. anyone found a solution? I can login and download using the DIM no problem but like the management above, I can't login to the server from DS.
  • Chakradude, I had a pretty indepth conversation with Totte on CMS connection issues. I still  have not gotten it solved, though maybe you will have better luck.
    Here's a link to it.
    https://www.daz3d.com/forums/discussion/276991/postgresql-cms-connection-on-a-mac#latest
