I am in dire need of help.
I am new to Daz Studio, former Poser user. But decided it was time to make a change. I have been having loads of fun with converting older items to Genesis 8. But as the title says, i need help. I am trying to convert Aery Soul's Justice armor and it worked out fine, until this...
As you can see, the arm is a glove and it has attached to it, 3 pieces of armor, shoulder, elbow and front arm. When I convert the left arm, only the glove shows up and the armor pieces are gone. I have been trying to unparent them and make them into a separate wearable preset, didn't work. Exported them and imported them and trying to fit them, didn't work either. Can someone please point my nose into the right direction, because i am lost. Thank you kindly for your time.
  • I would try unparenting the props, then fit the glove and let DS convert it, then use the posing tools on each prop to bring it into the correct position relative to the new figure 9and adjust scale if needed) and parent it back to the glove bones. Once that is done it certainly should be possible to save a new wearables preset - check that the right things are checked in the option dialogue.
  • @Richard Haseltine, thank you for your reply and i just did that, but as soon as i parent them, they go *poof*. Gone. It's driving me nuts. frown
  • Going by the image looks like a "T" to "A" situation ... try using my auto-fit clones ;-)
    Yeah.....no....already did that cheeky, still not working sadly, will convert something else, untill i get a luminous idea....better not hold your breath. wink
    Is Parent In Place off or on?
  • Parent in place is off.
  • Thanks for all the help, finally got it to work...well sort of. Sleepless night well spend. wink
