Wonder Woman Hair
So, I'm done with a Wonder Woman based on the TV series, but really need something closer to the hair style she wore on the show. I have something that is close, but does not have that fulld, swept back look. I chcked here and Renderosity, but maybe I missed something?
  • XyetztXyetzt Posts: 27,535
    Oh that Wonder Woman not Gal Gadot,
  • WSCWSC Posts: 157
    No. Working on that one too....
    https://www.daz3d.com/delphi-hair-for-genesis-3--8-females
    Comes closest afaik. If only had it had a bit more volume. Where is the DAZ hair conditioner and hairdryer? ????
  • grinch2901grinch2901 Posts: 1,247
    Two things you can try if a hair product is a bit too whispy looking.  First, you can try rampint the opacity up past 1.0. You probably have to turn off limis first, then set it to 1.5 or something. Sometimes that does the trick.  The other thing to try is to create a geometry shell and copy all the materials from the original hair to the corresponding materials on the shell. Now you basically have a dupilicate item, offset by a small ammount. You can tweak the offset (including making it negative so it lays under the original hair until it is in a position where it fills in gaps.
  • WSCWSC Posts: 157
    Yes, I think it needs more of a swept back look....
    Thats great advice! Thank you Grinch
  • WSCWSC Posts: 157
    edited August 2018
    I think I found something that may work. Miranda Hair at Rendersosity. I'll need to work on the curls....
    377 x 437 - 42K
    Post edited by WSC on
  • Can someone please tell me where can I find something similar hair like these hairstyles? Please?! Thank you
    611 x 960 - 76K
    725 x 544 - 169K
    725 x 544 - 137K
