The Divide (SKU 67065) pants rigging issue
Has anyone else encountered a rigging issue with the pants in The Divide Outfit and Props for Genesis 8 Female(s) (SKU 67065)? When the Left Thigh gets bent further than to -60, the pant leg separates from the figure. The attached pictures show the behaviour on a default G8F figure at -61 and -115 thigh bend. The right leg is OK.
Is there anything I can do on my end to fix this issue? Do I need to contact the creator (Dark Edge Design)? Is this broken for good?
UPDATE: Actually, I just found a work-around! When I auto-fit the pants to a G8M and then to a G8F again, the weird deforming behaviour disappears and the pants fit, no matter how far I bend the left leg.
Post edited by ABCA on
Send a ticket in to daz about it. If that's not meant to happen, it needs a fix and the only way to get that, is for daz to be aware of the problem.
