Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
There's a very wide selection still to be found: to be fair, you didn't specify what sort of alien. Many of them aren't aliens per se, but might do for alien skins in a pinch. I hope that one or more of these will suit your needs.
Mostly V4, but they'll work for the other two without too much fuss (some have textures+, others not so much):
That should give you enough to start with, anyway. And if you see one that looks familiar, by all means, go for it. It might be one of those you misplaced.
Lots there to work with. Thanks a lot!
Sure thing!
Thank you for the "no crack" morphs. I didn't realize I had to look under "no crack." Ah well!
--MW
Back with another inquiry... Has anyone seen a free doll figure or prop? I'm not looking for anime or BJD-like characters, but rag dolls or baby/toddler dolls.
It's not free, but Dolly Mine is in the PC+ for a day category today.
PIPPIN BASKET: http://kctc.francemi.net/index.htm?http&&&kctc.francemi.net/pippin_01.htm
Textures and hair fit (You want the pippin basket set look for the Download link just below the image): https://redeyecat.wordpress.com/2013/09/17/halloween-freebie-send-in-the-clowns-k4/
Hair: https://www.sharecg.com/v/36385/view/21/DAZ-Studio/M4-Short-Dreads-Hair
You may have the free Rag Doll from the 2006 Christmas advent by Digital Cats Media. File would be called DAZ_PAs_2006_DCMSBT.zip.
Here are two more for your consideration:
http://sanzisannzi.blog83.fc2.com/blog-entry-286.html
http://sanzisannzi.blog83.fc2.com/blog-entry-107.html
There's another rag doll prop or character at http://www.realmofsavage.com/Britta_dloads.htm as well.
https://web.archive.org/web/20200218094658/http://www.realmofsavage.com/Britta_dloads.htm
Sorry - download isn't working there either ...
Weird: I went right to the page before I posted the link.
The site is now functional. http://www.realmofsavage.com/Britta_dloads.htm
Anybody know of a freebie Michael 4 Boris Johnson lookalike(ish) ? Anything between the real person and Spitting Image puppet will do.
Alternatively, does anybody have a dial-spun M4 morph for him ? I have a large selection of non-free M4 morphs from the old days when I had cash and was in the real PC, but not the talent to use them to create lookalikes.
Accuracy isn't overly important, since I'll be using one of the freebie evil clown greaspaint makeups from MortemVetus. In fact, looking just a bit like him is possibly better.
Also any suggestions for free hair to go with it ?
PC+ instead of free, but this hair might work for Boris Johnson: https://www.daz3d.com/beach-hair
Or this: https://www.daz3d.com/duke-hair
Or this: https://www.daz3d.com/pyrit-hair
Good luck!
I noticed that lip-sync is gone from current DS Beta versions, unless it's just a problem on my side. But I am wondering if mcasual could create a script that allows for lip-synching to audio files with the same movements, such as moving the figure's head and occasional blinking to the audio?
https://www.sharecg.com/v/21560/poser/Orc:-Base-Figure
Hi to all, there is a Genesis morph who hide nose and ears?
https://sharecg.com/v/94004/gallery/21/DAZ-Studio/InTheFlesh-Merchant-Morphs-for-G8M-Vol.-1
https://sharecg.com/v/94074/gallery/21/DAZ-Studio/InTheFlesh-Merchant-Morphs-for-G8F-Vol.-1
I only know of G8 versions, don't know if that's any use to you.
Hi, I think this should be what you're looking for if you're using Genesis 1
https://sharecg.com/v/57901/browse/21/DAZ-Studio/SickleYields-Mutations-For-Genesis
From the description: This is a set of ten free and totally custom morphs for Genesis in DAZ Studio 4. There are morphs to remove lips, ears, and nose, to add claws, for three-fingered and two-toed looks, and to add catlike facial proportions
Pyrit hair, as that's the only one of the three I have installed, His skin colour needs a bit more fiddling*. But the likeness is truly uncanny !
*For my second attempt I used the UV2 version and layered a solid RGB(186,83,104) over the standard UV2 map in additive mode (in GIMP)
I keep seeing people on DeviantArt with 3D My Little Pony models. Does anyone know if there is a version of those for Daz? All I've seen is Blender versions, but I figured it wouldn't hurt to ask, since my kid is super into MLP right now.
Not Dazstudio, but Poser (which is easy enough to use in DS):
https://poserdazfreebies.miraheze.org/wiki/My_Little_Pony_Resources
Thank you!
LOL, I was wrong. The Orc's jaw is too chiseled!
Looking for Forsythia, preferably both bare branches and yellow spring flowers.
This is not Forsythia, but Coastal Wattle from down under. I believe that if you apply the flower and leave shapes you will have something similar. http://xfrog.com/product/OC41.html
If you downloaded the Xfrog samples in and around 2014 then you may have a model of Forsythia. File name is LS12_Forsythia_obj.zip
Ukor the Ogre might be a better model:
https://poserdazfreebies.miraheze.org/wiki/Ukor_the_Ogre
Anybody know any good "getting out of the swimming pool" poses? Using those little ladders that most pools have, or otherwise?
I need reins for the Horse 2 - dynamic reins that can be adjusted to hang down in front of the horse - either free or gathered in someone's hand that's leading the horse, be up over the neck grasped by a rider, and posistioned in other ways that real reins can be.
