Content Library PANE gone AWOL (4.12.2.54 Pro Public Beta)
pjwhoopie4801218
4.12. 2.54 Pro Beta
Downloaded to test it out... but for the life of me, I can't find the "Content Library" Pane. The Smart Content is there... but I am not seeing a way to get the tab for the Content Library.
Am I missing something? Tried to search to see if anyone else had this problem, but there are a lot of instances of "conent" and "Library" so I found no joy.
Any help?
Is it available in Window > Panes?
No... it has gone awol.
In Help > About Installed Plugins, does Content Library Pane have a green plug?
No... I think you are on to something..It says "Plugin failed to load".. what do I do to get it green?
If you click on it, what path and version does it show?
Make sure DS is closed, completely (not still shutting down as a background process in task Manager), then uninstall and reinstall - I suspect an older version of the fiel was somehow left behind.
That is what happened (I guess).. re-installed via DIM and all is right in the world... for now!
THANKS!!! Mike & Richard!
