Do these items look good in 3Delight?
I haven't had much luck with Iray to 3Delight converters.  Do these items have 3Delight mats, look good in 3DL out of the box, or require minimal tweaking to look good in 3DL?
https://www.daz3d.com/sy-guards-billboards-iray
https://www.daz3d.com/6-coffee-cakes
https://www.daz3d.com/thief-tools
Many thanks
  • LinwellyLinwelly Posts: 6,070
    I'm pretty sure the thief tools will do fine, the emissive parts would need to go into ambient channel and maybe add a linear point light, the metall parts might need a 3delight metal shader.
    I could test that for you if you're interested, since I have those.
    the other two I don't own. The billboards might be a bit tricky to get the right effet, might be as wel needed aome ambient with them.
    the cakes, probably will be fine the PA works with normal maps pretty much. So I expect that to be true here as well.
  • fixmypcmikefixmypcmike Posts: 19,742
    Thanks for the info, if you could test the thief tools I'd appreciate it.
  • TaozTaoz Posts: 10,384
    Here's the cakes right out of the box, with a single distant light:
    1330 x 901 - 1M
    Thank you
  • BTW there is a whole lot of 3DL food out there if you look. When I was looking for food to dress a dinner scene a year ago I found way more 3DL than iRay.
    edited October 2020
    here are two renders in 3delight, first one is the tools out of the box still with iray surfaces rendered with one spot and one distant light
    the other one was a quick conversion of the surfaces using Marshians reflective raidance for 3delight and moving the screen texture into the ambient channel, I wasn't very accurate with choosing some surface conversion I guess
    hope that helps
    800 x 800 - 1M
    800 x 800 - 1M
    Post edited by Linwelly on
  • PorsimoPorsimo Posts: 359
    I've noticed that in many cases the end result looks better with the original Iray materials (in 3Delight render) than manual conversion (by just applying 3Dl shaders). Shiny metals, glass and emissive surfaces naturally won't look good without some extra work.
    No don't do that! Unless you like really long rendertimes and super glossy flat looking surfaces. laugh
    since I alter a lot of iray surfaces which are already iray before rendering them in iray I would give the 3delight version the same amount of care to make them look astute. There is a lot to gain from that
    I was just a bit hurried with those above since I wanted to give the op an idea how they look
    Thanks, everyone, this has been very helpful
