Moshi the Kitten-fur invisible
Hello! I am experiencing an issue where the fur for Moshi is invisible. As you can see in the screenshot, his fur is loaded, but it will not render out. Am I supposed to be doing something in order for his fur to work? I've tried using the different colors and that doesn't work either. Any help would be greatly appreciated.
  • LeanaLeana Posts: 13,348
    Is that an actual render or preview? And are you rendering with Iray or 3DL?
    Hi. Well, I guess I should have tried to render it out. Your question made me try it, and the fur is fine. Feel like a moron, but I've never seen something that didn't show up in preview. Thanks!
    dForce hair uses lots of resources, so by default it's usually set as not visible in preview.
