Download Errors?
2»
  • DripDrip Posts: 1,277
    I managed to download most of my problematic files through my browser by now, except for part 4 from Porefectionist, which was by far the largest one.
    The point where downloads fail varies a lot. Sometimes at 4%, other times around 70%.
    The download manager built into Firefox actually attempts to resume a download before retrying, so it is sometimes possible to retry a few times and actually progress from the point where it left of.
    Sometimes, however, the download manager claims a succesful download, but only writes a 1Kb file. Opening that file in notepad revealed some interesting content. It said "Auth expired", nothing more, no weird codes or garble, just "Auth expired". For the rest, the file is useless, so I throw them away when that happens, and get back to trying to get a lucky streak in resumed downloads.
  • DAZ_RawbDAZ_Rawb Posts: 817
    Still failing for me as well.
    (Lyssa HD for Elithia 8 is 95MB, so not a huge product... still fails.)
    We made a configuration change on Saturday that should have fixed all of this.
    I just tried a manual download of that product and it worked fine for me, is it still giving you problems?
  • I just tried and am still having problems with Failed - Network error. Here is my list of items
    Not working
    Muelsfell Hagswood  item# 22177  *Ps.zip file
    Muelsfell Modular Path Set  item#55457  *Ps.zip
    Nature - Plants Pack 1  item#17357  *Ps.zip file
    Don't Use DIM but here are some non working files as well
    Water Spring  item#33097  1_33097.sep
    Tactical Belts  item#51973  1_51873.sep
    This item did not work until later yesterday and is still working today
    Morphing Jack-O-Lantern  item#64879  *.zip
    Hope this helps!
  • Mark_e593e0a5Mark_e593e0a5 Posts: 1,603
    edited October 2020
    ...and another one. The other files of that package DL'ed ok, including Carrara and Poser content (which I have no use for).
    1452 x 174 - 49K
    Post edited by Mark_e593e0a5 on
  • azoohouseazoohouse Posts: 664
    As of now, things are still failing to download. See attached
    623 x 209 - 32K
  • NylonGirlNylonGirl Posts: 2,447
    Whatever they did, they should have maintained a backup copy of the files for the server. It seems at this point, it would have been more practical to restore from the backup and just start over on whatever update they're trying to do.
    Finally managed to get the fourth package from Porefectionist. Not sure if anything was changed anywhere, but suddenly it all downloaded in one go.
  • Gr00vusGr00vus Posts: 372
    I'm having this problem with Super Hero Suit for Genesis 8 Female(s) (Product Sku: 71557) as well.
    Alright, I see that this problem has not been successfully resolved.
    I'm in contact with our cloud provider for downloads and will update you when we have a resolution. I have seen files that were previously unavailable become available so this could be a sign of some overloaded servers on their end that are being rebalanced over time.
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    edited October 2020
    FYI, manual DL also failed for me.
    EDIT: Got it on the second try. (Or, in Batman terms, the first try.)
    I'll see if a larger manual download works...
    1061 x 615 - 120K
    Post edited by The Blurst of Times on
  • Okay!
    Manual download for "Celestial Moon Weapons" also worked (~270MB).
    DIM was also able to process "Physical Therapy Equipment", which failed previously.
    Maybe it's working now.
  • LinwellyLinwelly Posts: 6,070
    DIM download of Highlands failed agian today
  • brvsnbrvsn Posts: 213
    edited October 2020
    after 3 days I was finally able to download 3 packages I had problems with, so for me it's solved, hope it gets fixed soon for everyone
    Post edited by brvsn on
    Thanks Rawb, whatever you and the cloud provider are doing is working for me at least. All my downloading is caught up!
  • pdspds Posts: 593
    Seems to be sorted out finally. Thanks, @DAZ_Rawb
    Got the Highlands through now as well :D
    Weekend purchases and today's downloads have now all completed. I think I just buy too much! ;)
  • Downloads completed. Thanks @DAZ_Rawb
    I'm seeing good results over here as well. I think this is fixed up for real.
  • I am still having product updates issue failing to download. Sad thing is, I submitted a report and got a form response back saying that everything was fixed. When I said I was still experiencing problems, just got the same response again that things were fixed and my ticket was "closed." Sigh.
  • tsroemitsroemi Posts: 3,676
    My failed downloads worked just now, sorry to hear others are still heaving problems though ...
    As long as they're not heaving bosoms, I think they will be okay. Also, I have been able to download things that wouldn't download earlier.
