Is there a better way to do it?
All of my DAZ resources under "My DAZ 3D Library" exceed the size of my hard drive. I presently off loaded it on to a 2 terabyte ScanDisk external drive. The problem is that I have less than 200 gig left. Once I fill this up, is the only solution to move to an even bigger hard drive or is there a better solution?
  • fastbike1fastbike1 Posts: 4,083
    Move to a bigger drive. They are ridiculously cheap and your DAZ assets aren't likely to shrink in the future. You also really don't need an SSD for the assets. Even a USB 3 external drive won't slow things down enough to be problematic.
    Instead of replacing your drive with bigger ones, the SysInternals junction let's you move for example the textures to other drives without braking the folder structure.
    https://docs.microsoft.com/en-us/sysinternals/downloads/junction
    I found it when I had the same problem with SSD drives and the bigger ones were just too expensive.
