Show Us Your Bryce Renders Part 11
15051535556100
  • Rieke77Rieke77 Posts: 619
    @ Horo - another wonderful render and I like the terraces.
    @ Electro-Elvis - the wood textures looks great and the lighting also.
  • mermaid010mermaid010 Posts: 6,182
    edited October 2020
    Adbc - The important thing is you completed the model,it is a beautiful model, like Horo mentioned with lots of potential.
    Electro-Elvis - wow beautiful image and lighting. Thanks for the comment.
    Still using the Hi-Res set 4 preset this was an experiment in rendering, the 1st is regular 8mins and the 2nd premium TA 36rpp took almost an hour,  and an anaglyph to complete the set.
    ETA: the buildings are Block 3 by Drachenlords and the lighthouse a freebie
    900 x 506 - 376K
    900 x 506 - 374K
    900 x 506 - 398K
    Post edited by mermaid010 on
  • HoroHoro Posts: 11,571
    Elektro-Elvis - thank you. That ballroom came out nicely, very good lighting, too.
    adbc - thank you.
    memaid - very nice terrain. I prefer the first, the TA is a bit low contrast; the anaglyph looks great - a bit on the dark side as if Maximum Ray Depth in the Render Options is a step low.
  • adbcadbc Posts: 3,115
    mermaid : I prefer the first render, beautiful terrain, great texture on the water and the anaglyph looks great.
    Horo - thanks, I wondered why the anaglyph looked dark but it worked after I reduced the haze so I did not look further. I will check the MRD - it will be 4 I think as I used the source file.
    Adbc - thanks
    @ mermaid010 - wow, this looks awesome. I like also the first render. Very nice textures and great anaglyph.
    mermaid - if you used any of the anaglyph sets, MRD needs to be 6. Each transparent surface the camera must look through or mirrors needs 1 ray depth.
    edited October 2020
    Thanks Rieke
    Horo – I knew about the MRD being 6 but forgot this time. Although I did find the anaglyph dark I didn’t make the connection.blush
    Here’s a re-render
    900 x 506 - 443K
    mermaid - yes, happens to me as well now and then. Great improvement, ws worth re-rendering it.
    Thanks Horo
  • Tim82Tim82 Posts: 859
    @mermaid010, it looks really awesome :) ....great job !!!!
    mermaid : your re-rendered anaglyph looks great.
    Thanks Tim and Adbc
    edited October 2020
    Same terrain as at the end of page 52 but from another angle. The unprocessed terrain was mixed with the processed one, given different materials and put up a slab of clouds. Sky colour and ambient light by a clear sky dome HDRI (PlaineMorte_CSD).
    The anaglyph has just a bit less haze and a bit more HDRI Effect.
    Striated Spot
    Striated Spot Anaglyph
    1200 x 795 - 242K
    1200 x 795 - 324K
    Post edited by Horo on
    Horo- outstanding renders, the anaglyph is awesome
  • HansmarHansmar Posts: 3,184
    Electro-Elvis: Very nice low viewpoint and good looking vegetation in the one render. Thanks for your comment on mine. The lighting in your ballroom render looks very good, just like the textures, indeed. Wonderful light through the windows.
    Adbc: Thanks. What a nice mood in your ice-cold render. I agree on the less successful part of what now appears to be a window. Maybe a small light outside of the window might have made it less harsh.
    Horo: Thanks also. The terraces in the hidden harbor render are supposed to be layers of houses or buildings. But maybe the boat is a bit large, indeed. I love your new TE-filter modified terrain. Will a new version be available for all?
    Mermaid010, Rieke77: Thank you.
    edited October 2020
    I made a new render with my last complex landscape. This is a view from the other side (more or less), with another sky. You now see that the cut-out of the lower terrain is rather harsh. But I like it. The holes you see in the lower terrain are caused by the fact that the negative terrain has spikes as well as a fractal terrain. I added a Genesis 2 figure with clothing and a weapon. To keep the Mb-count low, I deleted most of the actual figure, because it was covered by clothing anyway. And I changed the clothing textures to procedural textures in Bryce, which is of course no problem with a view from this far. The sky is one of the presets, but with the sun a bit more than 100%. Regular rendering in a couple of hours.
    Title: Taking the dangerous path.
    1754 x 875 - 2M
    Post edited by Hansmar on
    Hansmar - thank you. Concerning TE-Filters, I sent you a PM.
    I really like your idea to cut a landscape by a negative one. This gives many new possibilities. I like this new work of yours.
    edited October 2020
    Horo : excellent render and anaglyph.
    Hansmar : great idea, beautiful landscape.
    Thanks, you're right about that dark spot, I might try to make it better later on.
    In the meantime I made an image with one posterized terrain, view from inside, "depth".
    940 x 750 - 175K
    Post edited by adbc on
    adbc - thank you. Amazing render, gives a feeling of a very long and deep corridor. Great light and colours.
    edited October 2020
    Horo : thank you.
    I reworked that cave, adding a light (like Hansmar suggested) did not work, I adapted the sky settings to get rid of the dark window opening.
    1000 x 500 - 124K
    edited October 2020
    Horo, adbc: Thank you. Hope you start trying cutting landscapes! Of course you have all done it already for e.g. rivers or such. But maybe using it for random modification of existing terrains has its uses.
    adbc: The dark window is gone, but, like you said earlier, part of the charm has left too. Now the window is again a bit light, perhaps. I know, you can keep modifying and changing and trying to find the best solution. I often finally decide to settle for 'OK' instead of 'perfect'. And your terrain with posterize is dazzling!
    Hansmar : thank you. About that window, it's absolutely true and looks quite OK to me.
    @ Horo -  terraces and anaglyph are very beautiful.
    @ Hansmar - dangerous path looks awesome.
    @ adbc - wow, I like the view inside the depth.
    Your cave is so beautiful and I think, a stone window frame would also looks good.
    edited October 2020
    adbc - the not-black-anymore window makes a huge difference and there is light on the steps from the window.
    Rieke77 - thank you.
    The camera with the extreme wide-angle fisheye lens within a 6-sided pyramid, a bit transparent, reflection and bump, with an HDRI inside, and tone-mapped outside.
    Veined Bubbles
    1200 x 1200 - 476K
    Horo, Rieke77 : thank you.
    Horo : cool render, fantastic colour effect.
    adbc - thank you.
    @ Horo - oh wow, this looks fantastic. I love the colors.
    Thank you Rieke77.
    Hansmar- nice idea, the great landscape.
    Adbc - I agree with Horo, love the colors and depth. I like the re-render of the cave.
    Horo - wow an amazing mix of colors and shapes, fantastic render
