Bridge problem....
Boomerz
So I can't find the add-on in Blender. I've installed it via DIM, but it doesn't show up in blender and there's no zip file to install either.
Could someone maybe upload the zip file and post it here? and maybe that will do the trick.
You can only legally get the file from Daz 3d
https://www.daz3d.com/blender-bridge
but the problem is that it doesn't come with the zip file that's needed in order to do a manual install in Blender...
Then you need to contact Customer Service.
If it's the newest iteration of the bridge, you don't need the zip file if you installed through DIM. Just search in the add ons section of Blender for armature and find the one that has either daz or DTB and check it.
I get to correct a Mod? No way...
Sorry, Chohole, and no disrespect intended, because I love you and your big stick.
I have never used DIM, and I have installed a legally accessed Daz To Blender bridge.
I hand installed everything from ZIP as the OP wants to do -- The legally obtainable version is at Daz3D's own Github page : https://github.com/daz3d/DazToBlender
Note to OP if you go this route -- The github version might not be up to date with the DIM version, and intermeditate to advanced install skills might be needed.
