The Disappearance of GoZ for Mac
I could use some help. It appears my GoZ has gone missing. I was having an issue with it receiving information back from Zbrush. So I followed the instructions that I should reinstall the bridge. When I uninstalled from Install Manager, the bridge did not reappear in my "Ready to Download" section. The 32 bit version of GoZ is there, but not the 64 bit version. Anyone else have an issue like this?
Cheers,
Bill
It's not in Ready To Install either? Does it appear if you check the Show Hidden option? Do your download filters include 64 bit software?
Did you check in "Ready to Install"? You have to delete it from there after unistalling before it will show as "Available to Download"
Sadly this didn't help me whwn it come to fixing the problem with sending back from ZBrush.
Thank you for your comments. I had to use my Mac Time Machine to turn back to a version of Studio that contained Zbrush and then moved forward.
Thanks again.
whfield
