v3 morph to v4?
IkyotoIkyoto Posts: 1,159
wasn't there a product to do so? any ideas?
    No it is the opposite way round V4 came with a V4 to V3 figure which allows V4 to wear V3 clothes. It does use the V4 skin and head morphs.but the body is just the standard V3 one, no morphing.
    Sure, use GenX and add the V4 morph and then you will have V4 and then you can add any V3 morphs with this http://www.daz3d.com/genx-addon-gen3-for-v3-and-m3 also.
  • CybersoxCybersox Posts: 9,924
    That's true if if it's already a V3 morph and you want to transfer it to Genesis or one of the G2 figures. However, if I'm following the poster's chain of thought from another thread http://www.daz3d.com/forums/discussion/40608/ , this is actually concerning a v3 face morph target (obj) that they want to apply to V4. I think the product the poster is actually referring to might be Morph Designer http://www.daz3d.com/morph-designer-3-0
  • KeryaKerya Posts: 10,943
    Yes. :)
    Using the V4.2 to V3 figure:
    You get the basic V3 body shape with the V4 head, you can use V4 head morphs to change the face but neither V4 nor V3 body morphs.
    Workaround: If you have Morphing Clothes by Dimension3d, you can transfer V3's morphs into the V4-V3 figure.
    You would treat V4toV3 as a clothing and transfer V3 morphs to her and save as a new cr2.
  • IkyotoIkyoto Posts: 1,159
    Sounds right, but
    i can't find the product OR get DS4.6.2.118 to export a cr2
    Sounds right, but i can't find the product OR get DS4.6.2.118 to export a cr2
    Morphing clothes:
    http://www.renderosity.com/mod/bcs/morphing-clothes/64629/
    (I hope this link stays at is an answer to a direct question ...)
    Morphing clothes saves the new cr2 - you don't need to do it in DS.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,514
    it may be possible to use crossdresser too
    I have used it to add V4 morphs to other figures and only have the V4 license and morph plugin for XD3
    reson i was askin was to update this v3 character i made a long time ago
    733 x 836 - 22K
