v3 morph to v4?
IkyotoIkyoto Posts: 1,159
wasn't there a product to do so? any ideas?
    No it is the opposite way round V4 came with a V4 to V3 figure which allows V4 to wear V3 clothes. It does use the V4 skin and head morphs.but the body is just the standard V3 one, no morphing.
  • FSMCDesignsFSMCDesigns Posts: 12,858
    Sure, use GenX and add the V4 morph and then you will have V4 and then you can add any V3 morphs with this http://www.daz3d.com/genx-addon-gen3-for-v3-and-m3 also.
  • CybersoxCybersox Posts: 10,038
    That's true if if it's already a V3 morph and you want to transfer it to Genesis or one of the G2 figures. However, if I'm following the poster's chain of thought from another thread http://www.daz3d.com/forums/discussion/40608/ , this is actually concerning a v3 face morph target (obj) that they want to apply to V4. I think the product the poster is actually referring to might be Morph Designer http://www.daz3d.com/morph-designer-3-0
  • KeryaKerya Posts: 10,943
    Yes. :)
    Using the V4.2 to V3 figure:
    You get the basic V3 body shape with the V4 head, you can use V4 head morphs to change the face but neither V4 nor V3 body morphs.
    Workaround: If you have Morphing Clothes by Dimension3d, you can transfer V3's morphs into the V4-V3 figure.
    You would treat V4toV3 as a clothing and transfer V3 morphs to her and save as a new cr2.
  • IkyotoIkyoto Posts: 1,159
    Sounds right, but
    i can't find the product OR get DS4.6.2.118 to export a cr2
    Sounds right, but i can't find the product OR get DS4.6.2.118 to export a cr2
    Morphing clothes:
    http://www.renderosity.com/mod/bcs/morphing-clothes/64629/
    (I hope this link stays at is an answer to a direct question ...)
    Morphing clothes saves the new cr2 - you don't need to do it in DS.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,822
    it may be possible to use crossdresser too
    I have used it to add V4 morphs to other figures and only have the V4 license and morph plugin for XD3
    reson i was askin was to update this v3 character i made a long time ago
    733 x 836 - 22K
