• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Almost all black render
SnowSultanSnowSultan Posts: 3,803
October 2020 edited October 2020 in Blender Discussion
Does anyone have any suggestions as to what might be causing this problem? It's a Cycles rendered preview of an imported Genesis 8 Male figure (as an OBJ). Other .blend files I've made in the last few days render fine, so I assume it's something with the mesh. Thanks for any information.
Post edited by SnowSultan on October 2020
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,306
    @SnowSultan
    Flipped normals?
    Edit to be more helpful:
    Go to the Viewport Overlays in the upper right of the 3D Vieport, and select "Face Orientation". If it's all red instead of all blue, the normals are flipped.
    In that case, just go into edit mode for every object, and Mesh|Normals|Flip them.
    If some are flipped and others are not, I'd do a Mesh|Normals|Set from Faces
    Post edited by TheMysteryIsThePoint on October 2020
  • SnowSultanSnowSultan Posts: 3,803
    October 2020
    Thank you, that was the problem, but when I flipped them (from red to blue), they're still rendering all black. I'll experiment a little more (maybe it needs to be saved and reopened?), but I'm curious as to why that didn't solve the issue, as what you explained was exactly what was going on.
    October 2020
    Strange.
    Try going to the Shader tab, and see if there is anything obviously wrong on each material. Whenever I saw an all black object while working on Sagan it was because a normal map node was referencing a non-existent UV map, and I'm not sure what your OBJ has.
    October 2020
    I ended up deleting the OBJ file after it completely crashed Blender to the desktop upon re-importing. It was just a test, so no work lost. I'll assume something was messed up on export. Thank you very much for the useful information.
    October 2020
    Just one more little question, I didn't want to clutter things with a brand new post for something simple. Everything I export from DAZ Studio comes into Blender rotated 90 degrees on the Y axis and facing 180 degrees the wrong way (on Z axis). Could someone tell me where you can change these values so they import as they would in Studio? Thanks.
  • felisfelis Posts: 6,147
    October 2020
    In the blender import menu set under Transform '-Z forward' and 'Y up'..
    October 2020
    It's actually -Y forward and Z up, but thanks, that was where I needed to make the fixes.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
