i have an issue
fernfairy73_bb8ec3d37c
when i try to render Bella Bleu the render will not show in the render window then my computer starts to frezz and play up the daz crashes and sometimes my computer dose too, i tryed rending bella bleu on her own without the clothes and she renders perfectly but if i try to render her with the clothes everything gose heywire, i was thinking maybe my computer card maybe to old for the new genus's 8 i'm really disaponted as i brout the bundel ages ago and feel i have no use for it now i was thinking of giving to a friend who can render the new genus 8
also this keeps coming up
Crashing like that sounds like a hardware or driver issue. What are your system specifications? What security software are you using?
The second is a problem communicating with the database that drives the content management system - security software may well be the issue here.
i have trend micro when i acadently unistalled daz 12.4 then reinstalled it thats when everything started playing up
also what should the port number be
Go to edit > preferences > CMS settings in DS, you should see the port used.
its 1024 is this the right number
ok this is what it states
If you go to Installation tab in DIM settings, are the parameters for Content database the same as in DS?
its ok i fixed i found the plugin and reinstalled it woohooo all is good DAZPostgresqlCMS_9.3.4 this little beauty so happy
only probleam i have now is the Bella Bleu shuch a pitty i can't use it oohh well i wounder if i just do 3d lights and if she work hum hummm i can always try that
i still can't render bella bleu in iray but it works in 3d lights
test runs with 3d lighting is there a 3d light i can get that looks more like natural light like the sun sky setting of iray i love that look
i like the test run but i want it brighter
