Adding to Cart…
Not really happy with these IRay renders at all.
Any advice about how to get rid of all the noise would be great!!!!
Noise is an iray thing.
What works for me, is usually adding some more lights. and don't forget to use the noise filter. it helps a lot.
Last, but apparently that does not work for everyone, render bigger, then resize :)
Ghost lights also may help for an indoor render :-)
Thanks for the advice Mori I will do that net time I render it.
I I can't afford Ghost Lights right now, so is there another way to get the same effect @JoJoS?
"Ghost light" is a generic term, not just the name of a product. Create some low-poly planes, make them emissive, tweak the lighting and positioning to your needs, then lower opacity to .001.
Oh ok thanks for the advice @Gordig!!
Back to doing 3Delight rendering today because I just want to do a few renders using the content I got from July's PC+ sales,
Some advice woudl be great with this pic as well!!
Playing around with free M4 character and V4 character just to see how funny I can be with them!
done in 3Delight no postwork
Playing around with those poppies again!! God I just love those flowers!
Done in 3Delight again no postwork
Indoor lighting with IRAY is tricky!
So this is not a quick-and-easy solution (there's no such thing with IRAY indoor scenes, as far as I know), but here's what works for me most of the time:
- Use IRAY Section Planes to get rid of all ceiling and walls that are out of frame.
- Place an HDRI that fits more or less your scene. The HDRI can be low-res and doesn't have to exactly match your interior, it's just here to provide light and reflections.
- In Render Settings -> Environment, increase/decrease the value of Environment Intesity to increase/decrease the brightness of your HDRI.
- Still in Render Settings -> Environment, use Dome Rotation to rotate your HDRI.
- Place Point Lights in your scene to provide further accents if needed.
This should light your interior properly.
Now, to make the area outside the window brighter than your interior:
- Place a Primitive Plane outside your window. To make it emissive:
- Set Emission Color to white.
- You can place an image of a landscape or sky in the Emission Color slot, it will be visible through the window. In this case it's not necessary because the curtains are drawn.
- Emission Temperature: the standard 6500k is pretty good for sunlight. Lower the value to get warmer light.
- Two-Sided can be off for this purpose.
- Luminance: Increase the value to make the plane glow stronger. You might have to increase the value by a lot (try factor x10, x100).
Hope this helps!
Thanks so much for the great advice @Hylas!
I was messing around today in Da studio and my granddaughter told me I should do this kinda toony type image for all to see!!
Done in 3Delight and Used AoA ambient lighting postworked in GIMP
Titled: Alien Life
^ Hieronymus Bosch realness!
Thanks for that link @Hylas!!
Messing around in Daz again trying out some of my Landscapes and a tribute to Adam Thwaites freebie props!!
Done in 3Delight no postwork
Messing around with the Mil Cat and Low Poly Cats and Dogs!
Making the render for net month's theme for our freebie contest, but this is just the original render
Done in 3Delight and postworked in GIMP
I love it, well done:)
Thanks for the nice comments Sven!
Still trying IRay with some great new free clothes from Elleque Here, Here, Here, and Here,
Here is a different type of render for me with a different camera angle then what I usually do.
Was following along a tutorial and he was talking about different angles we could use for different scenes and this was the one I chose to do!
Here is the poster and Banner for this months theme for the Freebie Challenge!
Way to go, Saphirewild. Its been about 3 months or so since I had a chance to check out your thread. Too many new goodies to comment on them all, but a special shout out to your Belle and Blake renders. So much fun. Keep up the great work. I enjoy checking in and seeing what you have been up to.
Thanks so much @Diomede for the nice comments!!
I am trying to keep busy lately with my rendering as my body is still healing from a few months ago!!
Pretty soon I am going to try my hand ay modeling again just to see how much I have learned the past few months of watching tutorials about Hexigon!!
Was trying my hand at IRay night time lighting HDRIs and not sure if I am really happy with this render
Here is one I did outta da box!!
Done in 3Delight and Postworked in GIMP
Hi Saph, hope life has been treating you well. Although I'm rarely on forums anymore, I do occasional browsing, specially your thread, appears your having a fantastic time creating, very cool/fabulous scene renders. I truly enjoy viewing your progress. I love this render you did, always desired to do similar render. Great job on all you renders. Till next time friend, keep having fun creating.
Thanks @AJ2112 I have been working hard lately with my renders!!
Titled: Besties Arial and Amanda
Used: Elegant Fabric Iray Shaders , Contemporary Reading Lounge
