Saphirewild's Randomness Renders
1…5152545657…71
  • SaphirewildSaphirewild Posts: 6,729
    edited September 2020
    Not really happy with these IRay renders at all.
    Any advice about how to get rid of all the noise would be great!!!!
    800 x 640 - 1M
    800 x 640 - 1M
    Post edited by Saphirewild on
  • mori_mannmori_mann Posts: 1,152
    Noise is an iray thing.
    What works for me, is usually adding some more lights. and don't forget to use the noise filter. it helps a lot.
    Last, but apparently that does not work for everyone, render bigger, then resize :)
  • JoJoSJoJoS Posts: 50
    Ghost lights also may help for an indoor render :-)
    Thanks for the advice Mori I will do that net time I render it.
    I I can't afford Ghost Lights right now, so is there another way to get the same effect @JoJoS?
  • GordigGordig Posts: 10,836
    "Ghost light" is a generic term, not just the name of a product. Create some low-poly planes, make them emissive, tweak the lighting and positioning to your needs, then lower opacity to .001.
    Oh ok thanks for the advice @Gordig!!
    Back to doing 3Delight rendering today because I just want to do a few renders using the content I got from July's PC+ sales,
    Some advice woudl be great with this pic as well!!
    1500 x 1200 - 3M
    Playing around with free M4 character and V4 character just to see how funny I can be with them!
    done in 3Delight no postwork
    1500 x 1875 - 5M
    Playing around with those poppies again!! God I just love those flowers!
    Done in 3Delight again no postwork
    1500 x 1875 - 5M
  • HylasHylas Posts: 5,346
    Indoor lighting with IRAY is tricky!
    So this is not a quick-and-easy solution (there's no such thing with IRAY indoor scenes, as far as I know), but here's what works for me most of the time:
    - Use IRAY Section Planes to get rid of all ceiling and walls that are out of frame.
    - Place an HDRI that fits more or less your scene. The HDRI can be low-res and doesn't have to exactly match your interior, it's just here to provide light and reflections.
    - In Render Settings -> Environment, increase/decrease the value of Environment Intesity to increase/decrease the brightness of your HDRI.
    - Still in Render Settings -> Environment, use Dome Rotation to rotate your HDRI.
    - Place Point Lights in your scene to provide further accents if needed.
    This should light your interior properly.
    Now, to make the area outside the window brighter than your interior:
    - Place a Primitive Plane outside your window. To make it emissive:
    - Set Emission Color to white.
    - You can place an image of a landscape or sky in the Emission Color slot, it will be visible through the window. In this case it's not necessary because the curtains are drawn.
    - Emission Temperature: the standard 6500k is pretty good for sunlight. Lower the value to get warmer light.
    - Two-Sided can be off for this purpose.
    - Luminance: Increase the value to make the plane glow stronger. You might have to increase the value by a lot (try factor x10, x100).
    Hope this helps!
    Hope this helps!
    Thanks so much for the great advice @Hylas!
    I was messing around today in Da studio and my granddaughter told me I should do this kinda toony type image for all to see!!
    Done in 3Delight and Used AoA ambient lighting postworked in GIMP
    Titled: Alien Life
    1500 x 1200 - 2M
    1500 x 1200 - 2M
    1500 x 1200 - 2M
    ^ Hieronymus Bosch realness!
    Thanks for that link @Hylas!!
    Messing around in Daz again trying out some of my Landscapes and a tribute to Adam Thwaites freebie props!!
    Done in 3Delight no postwork
    1500 x 1200 - 3M
    Messing around with the Mil Cat and Low Poly Cats and Dogs!
    1500 x 1200 - 3M
    Making the render for net month's theme for our freebie contest, but this is just the original render
    Done in 3Delight and postworked in GIMP
    1500 x 1200 - 2M
  • Making the render for net month's theme for our freebie contest, but this is just the original render
    I love it, well done:)
    Thanks for the nice comments Sven!
    Still trying IRay with some great new free clothes from Elleque Here, Here, Here, and Here,
    800 x 1294 - 1M
    Here is a different type of render for me with a different camera angle then what I usually do.
    Was following along a tutorial and he was talking about different angles we could use for different scenes and this was the one I chose to do!
    800 x 1294 - 2M
    edited October 2020
    Here is the poster and Banner for this months theme for the Freebie Challenge!
    500 x 300 - 283K
    800 x 640 - 577K
  • DiomedeDiomede Posts: 15,469
    Way to go, Saphirewild.  Its been about 3 months or so since I had a chance to check out your thread.  Too many new goodies to comment on them all, but a special shout out to your Belle and Blake renders.  So much fun.  Keep up the great work.  I enjoy checking in and seeing what you have been up to.
    Thanks so much @Diomede for the nice comments!!
    I am trying to keep busy lately with my rendering as my body is still healing from a few months ago!!
    Pretty soon I am going to try my hand ay modeling again just to see how much I have learned the past few months of watching tutorials about Hexigon!!
    edited October 2020
    Was trying my hand at IRay night time lighting HDRIs and not sure if I am really happy with this render
    1000 x 800 - 1M
    edited October 2020
    Here is one I did outta da box!!
    Done in 3Delight and Postworked in GIMP
    800 x 640 - 448K
  • AJ2112AJ2112 Posts: 1,417
    edited October 2020
    Hi Saph, hope life has been treating you well.  Although I'm rarely on forums anymore, I do occasional browsing, specially your thread, appears your having a fantastic time creating, very cool/fabulous scene renders.  I truly enjoy viewing your progress.  I love this render you did, always desired to do similar render.  Great job on all you renders.  Till next time friend, keep having fun creating.
    800 x 640 - 497K
    Post edited by AJ2112 on
    Thanks @AJ2112 I have been working hard lately with my renders!!
    yessmileyheart
    edited October 2020
    Titled: Besties Arial and Amanda
    Used: Elegant Fabric Iray Shaders , Contemporary Reading Lounge
    800 x 1000 - 948K
