Adding to Cart…
You may need to uninstall and reinstall those plugins if you installed them before you had a Beta on that machine.I did, I do not run Beta's but I needed the TDLmake fix in this one. The Full version on my PC has a bad TDLmake issue. Thank you for the info. Any other files besides those I need to do?
Any plugins that don't have a separate package for the Beta.
I have a problem accessing content I previously created in DAZ Studio Pro - version 4.6.2.120 64 in Pro Beta 4.6.3.29 64.
I exported user data from 4.6.2.120 and then imported user metadata into 4.6.3.29. I noticed that the re-import metadata progress bar stayed on 0% the whole time but after several minutes the import completed and I was able to see my content library categories and their off-the-shelf contents. But the stuff I created just shows exclamation marks.
When I try to load one of these objects I get a resource error (see attached image)
The path is correct except for the <base_folder>/ element. Any ideas about fixing this?
Thanks - lucia
PS Using WIN7 64
%-P Hi
how can I test it?
Did you add your Content folders in Content Directory Manager? The Beta does not share settings with the general release.
Hi fixmypcmike, thanks for the fast reply!
I added the top level directories where I keep my content to the Content Directory Manager. In this case my SALES SCENE.duf file is in a sub-directory of a sub-drectory under Q:/DAZ/01 DAZ3.
Do I need the full paths to all the content directories?
Lucia
While I normally DON'T try beta software (Beta testing is not my job!) I decided to try this DS beta, as I was fed up with the content DB getting corrupted right after I repaired it over and over, and have no idea how long before the next standard release comes out. After installing the beta & checking that both version can run simultaneously (to compare changes), the new db seems to have converted content from the old DB ok and seems stable so far. Altho someone said we need to uninstall & re-install plugins and shaders, DIM seems to have installed them in the beta, altho I did copy the GenX2 & Luxus plugins to the beta plugin directory as suggested previously. And I got my custom style preferences & custom scripts transfered by copying over the action, layout, etc, dsx files. So I am happy to have the beta up to speed with my custom preferences so I can get back to creating instead of troubleshooting. :coolsmile:
Now, Is there anything most users need to do regarding the new PG DB administratively with the PGadmin tools, or can we just let it do its job in the background without interrupting the creative flow, as it should, IMO.
Also, where can we find some docs/tutorials on using the new Geometry Editor and other new features?
And again, Thanks to DAZ for this wonderful software. :-)
The intention of the CMS is to have you do as little as possible and just let it do its job. You should not need to do anything with it with any PG admin tools and any maintenance you may need to do, like add your own categories, or make Smart content work more is a way that works for your workflow, can all be handled from within DAZ Studio.
Hi folks!
Anyone knows where is the button/menu line to save as a figure (not wardrobe). I´ve been searching every single panel and bar and I haven´t found it.
Cheers!
Dan
No problem, I found my issue: I had "city limits" layout, changed to another one, and all the export options appeared in its place :)
