My Projects in 3D Digital Rendering
1151618202125
  • RakudaRakuda Posts: 938
    edited September 2020
    Beach Scene
    Another Figure in a Wicker Chair
    1855 x 2400 - 4M
    1236 x 1600 - 1M
    Post edited by Rakuda on
    Just a few environmental renders
    1112 x 625 - 689K
    1200 x 960 - 776K
    2400 x 1350 - 3M
    2400 x 1350 - 3M
    Encounter
    Attempted Escape
    1931 x 1492 - 448K
    1200 x 511 - 300K
    546 x 1200 - 635K
    900 x 900 - 309K
    1200 x 511 - 237K
    1200 x 960 - 1M
    edited October 2020
    Just a recent Hexagon model and a sample render. Maybe someone will recognize the table from somewhere...
    3D Model freely available here.
    https://sharecg.com/v/96569/gallery/5/3D-Model/Coffee-Table
    Not exactly the right color rug below, but I have to do a bit of drawing work to come up with a more subdued rug texture.
    1391 x 1112 - 1M
    1391 x 1112 - 2M
    edited October 2020
    A mockup of the carpet using some low-rez screen caps. Need to spend some time cleaning up that image map. The rug also needs a fringe.
    1391 x 1112 - 2M
    edited October 2020
    Here is a retro future bucket chair done in Hexagon. Also going to upload that shortly on sharecg as well.
    Sharecg.com download link (Use it freely without restrictions)
    1391 x 1112 - 972K
    1391 x 1112 - 631K
    edited October 2020
    A mesh screen model for casting light or using as a divider.
    1391 x 1800 - 1M
    edited October 2020
    A little better on the rug, Still, no fringe yet.
    A couble of extras that I are in the works:
    A door (which needs a frame)
    And a door knob/faceplate
    900 x 719 - 554K
    1391 x 1112 - 1M
    729 x 1200 - 302K
    729 x 1200 - 656K
    edited October 2020
    Working on this. I used some free textures, but I can't re-distribute them on Sharecg.com so I will have to spend a little time cobbling together a flat texture map. Plus, for looks I think it will be good to add two hinges on the side of the door.
    Wonder if I should go all out and individualize the wood panels in my door model instead of using a single map for it. The door would  probably look sharper that way.
    I think the hinges look good, but it isn't worth the effort individuating the boards on the door. From the distance I see rendering it, the benefit wont be worth the cost.
    729 x 1200 - 742K
    600 x 988 - 236K
    729 x 1200 - 666K
    729 x 1200 - 633K
    edited October 2020
    Working on an overall room for my setting.
    603 x 434 - 33K
    608 x 499 - 38K
    616 x 568 - 41K
    1100 x 543 - 79K
    1074 x 1074 - 1M
    edited October 2020
    Redesigned and tweaked the room a bit to get the doors just right. now I have to put some trim on the edge of the color change on the wall. Also, want to make that brown a bit more subtle on the image map.
    I think now the orange chair needs a bit of a version 2 redesign.
    Update:
    Looking better. I need to go mind the gaps between the new trim boards and adjust the doors. They need moving, a little but also need a little smut and grit around the surfaces where hands would touch for a little realism.
    Maybe in the next shot I will render a shot of the round front door in place.
    One might also notice a subtle difference that gave the room a little more space. Behind the arch, I put a bend in the wall and kicked it back about a foot and a half. That sets the near door back a tad bit, but just enough. The room is developing a sense of space.
    Update 2:
    The flam-damned front door doesn't fit. I have to tweak it a bit and also, the right wall needs the trim up top. But... it's coming along.
    1074 x 859 - 833K
    1074 x 859 - 869K
    1074 x 859 - 761K
    1074 x 859 - 821K
    edited October 2020
    Spent a little time redesigning the modern chair. It is a little closer to what I want. Having an issue with Hexagon however and smoothing. If I smooth, it has the unintended effect of also thinning or bringing the surfaces tighter in and reducing the thickness of the chair surface. I am trying to figure how to overcome this.
    Here is a rough draft layout of a plant stand that I am working on. Just wanted to see how it would work in the scene. It will have more ornate details when it is finished.
    600 x 480 - 61K
    1074 x 859 - 889K
    663 x 859 - 557K
    663 x 859 - 524K
    663 x 530 - 327K
  • Fae3DFae3D Posts: 2,909
    I try not to comment on people's Art Studio threads very often, for fear of messing up their "flow", but I just wanted to let you know that I find your work amazing!  Your creativity is inspiring!
    Also, I think I've downloaded just about everything you've made available, so thank you so much for sharing some of your work with us!
    edited October 2020
    @Faeofthe3rdDimension I really am grateful for your comment. It is very motivating and makes me want to create more good props and things to share.
    Here is a detail of the plant stand. I really want to focus as I complete it on reducing the geometry to the minimum necessary as there will be much detail.
    To anyone working hard creating things in 3d or on computers in general, I would say get up every once in a while and move your legs, stretch and get some fresh air every 20 minutes or so. It is good to take care of yourself and keep moving. Sometimes I sit in one place too long, especially in this pandemic being at home.
    Best everyone...
    ^__^
    663 x 530 - 301K
    edited November 2020
    Will get back to posting prop updates tomorrow for the environment.
    Just had to take a diversion and make a staircase and pose a figure on it.
    There is just too much going on procedurally with the conncrete textures.
    I need to come up with some better flat non-repetetive textures
    A slight improvement on the textures
    874 x 1440 - 2M
    900 x 1482 - 2M
    The last week and the US elections were a bit of distraction. But... here is a set of renders of a model I recently purchased.
    A test render using a panorama picture. I think I need to play around in Photoshop and make a sort of simulated HDR to get the gama right.
    900 x 720 - 401K
    900 x 506 - 268K
    900 x 506 - 295K
    900 x 1165 - 617K
    900 x 506 - 233K
    Getting on the road using Long Stretch of Forested Road
    https://www.daz3d.com/1stb-long-stretch-of-forested-road-add-on
    900 x 506 - 383K
    900 x 506 - 413K
    900 x 506 - 480K
    900 x 506 - 349K
    A little work done in Hexagon today. The windows are just a single image. I think it would be fun to take a standard window and render a buch of different scenes with different curtains, a cat in th window. some flowers, etc. Then I can vary it up a bit.
    1107 x 572 - 87K
    1200 x 1200 - 1M
    Here is a test render using:
    1. Farren HD for Genesis 8 Female
    2. Hd Flute And Poses For Genesis 8
    3. dForce HnC Short Sleeve Shirt Dress Outfit for Genesis 8 Females
    4. Click N Render IBL Set
    1200 x 960 - 385K
    1200 x 960 - 429K
    Another random test render of some assets.
    1. Night and Day City
    2. KA Carly
    3. Darsel
    4. Heavy Motorcycle Road Cruiser
    5. DForce Biker Outfit
    6. Syble Outfit
    1200 x 1200 - 965K
    1200 x 1200 - 1M
    582 x 960 - 363K
    1200 x 675 - 527K
    Dont hide your talents
    1200 x 1553 - 1M
    I took a Thanksgiving vacation and got home and very soon after literally got run over by a bus. I am basically learning to walk correctly, and dealing with injuries from a fractured pelvis. I have been yearning to get back to creating. It feels like time again.
    edited April 2021
    Just a little architectural setup of an apartment living room similar to my own. Kit-bashed a bunch of odds-and-ends.
    1855 x 2400 - 3M
    edited May 2021
    A few random renders from my AWOL period.
    900 x 900 - 232K
    900 x 556 - 280K
    edited April 2021
    Some various costume test poses
    600 x 777 - 189K
    900 x 1165 - 249K
    1978 x 2560 - 972K
    900 x 1165 - 246K
    900 x 1165 - 338K
    edited April 2021
    A few spooky and cool renders of the Albert Mansion set
    I would say the set was definitely worth the purchase.
    Here I took out the mansion and added some people in the middle of the grassy environment.
    Acrobats
    2400 x 1920 - 3M
    2400 x 1920 - 4M
    2400 x 1920 - 4M
    900 x 720 - 205K
    1854 x 1483 - 2M
    edited May 2021
    Bashing together a few retro prop sets
    900 x 720 - 280K
    edited May 2021
    Utopia Living Room
    Bought this because between it and a few other apartment settings, I wanted a few enviroonments to try out placement and feel of some art work on the walls.
    Here is another similar environment with two very different lighting setups and therefore different moods
    2400 x 1350 - 2M
    2400 x 1350 - 2M
    900 x 720 - 200K
    edited April 2021
    I used some props in Daz Studio as reference for a digital drawing that I was working on.
    900 x 1200 - 473K
    695 x 900 - 300K
    edited April 2021
    an interesting abandoned building found on a different site that I turned into a sort ot homeless crash pad. Who knows why...
    1390 x 1112 - 1M
    1800 x 1440 - 2M
    1800 x 1800 - 3M
    1800 x 1800 - 3M
    1800 x 1440 - 2M
