Having Trouble with Maximum Vasculum
ChrisKazChrisKaz Posts: 0
I recently bought and started trying the Maximum Vasculum morph set by RAWart. I am having trouble getting the morphs to show up in renders. I have updated to latest version of DS 4.6 and still nothing. Could someone help me out here.
    Make sure you set your G2M or G2F to have mesh resolution set to High and at least subdivision 2 (you can try 3 and see if it lags your renders too much).
  • ChrisKazChrisKaz Posts: 0
    edited May 2014
    I set the mesh resolution to high and the subDivision 2 for my G2M, and I still get no visible veins. I have all the sliders dialed up to 200%. What am I doing wrong? Or possibly not doing something I should be. HELP, please...
    Post edited by ChrisKaz on
    Save the file, close DS and restart it. I had to do this recently but I don't recall if I had to restart the computer as well. When mine gets warm sometimes it develops spontaneous errors with stuff like HD morphs.
  • JaderailJaderail Posts: 0
    edited May 2014
    Which render setting are you using? 3Delight?
    EDIT: You do know these are ONLY for the G2 Figures correct? They do not work at all on G1 figures.
    Post edited by Jaderail on
    I am using a custom render setting of 1200 x 1500 pixels, and yes I'm using the 3Delight render engine. I also know that Only G2 figures will work..
    Just asking as I do not have to do a thing except apply them to my G2 for them to work. Which version of DAZ Studio are you running?
    The latest version of DAZ Studio 4.6 just updated it today.
    DO I need to apply the vein morphs before i set any other morphs? I've been trying to use them on a G2M character I created before I bought and installed the Maximum Vasculum set.
    I have been trying to say something is off with your install. They work on any G2 with any morphs as just a click load if installed properly.
    Here is a G2 figure, morphed and all, it does not matter what order I do it in. They just work for me...
    I'm a 100% all DIM for all content Install...
    1000 x 1300 - 760K
    Thanks for the info... now i just need to figure out where it went wrong. I was until recently a manual install for all content. And I've not had any problem, I hope i can fix whatever i did wrong.
    With the old character loaded and selected load a new G2M and when asked "Load a new Figure..." or "Apply this Character...", pick "Apply...". After the the figure has been applied hit undo to get your old character back but now with the newest morphs added.
    If you just started using the DIM for content installs you do know it, DIM, defaults to a different content folder. The new DIM folder would need Mapped to DAZ Studio before files would work. The Icon will show because it was Installed into the CMS Database. The Real folder path would still need mapped before the Icon would function.
    Here is DAZ Studio Mapped to both default content folders...
    429 x 467 - 62K
    I worked With DIM during the day and I figured that very thing out. Bu I also realized that I had only installed the files for G2M vein morphs, leaving out the ones for G2F. Despite the fact I have nothing else for G2F installed not even the base figure. But thanks. for all your help. I did finally get it to work.
