Morphing Fantasy Dress Slit?
nightwolf1982
I'm wondering how to go about creating a decent slit in the MFD skirt. I know I could do it with transparency maps, but I suck at painting them. Barring that, is there a dress similar to the MFD, but with a slit in the skirt?
Perhaps this: http://www.daz3d.com/high-low-skirt or a part of this: http://www.daz3d.com/guardians-of-the-flame-for-genesis? What kind of slit are you looking for by the way?
Basically this: http://images6.fanpop.com/image/photos/36200000/Elsa-the-Snow-Queen-image-elsa-the-snow-queen-36269667-1920-800.png
http://www.sharecg.com/v/75595/browse/21/DAZ-Studio/Two-Dress-from-film-Frozen-for-G2-Female
Wilmap's got you covered :).
It's a nice outfit, but not what I'm looking for. I'm trying to re-create the slit in the ice dress, using the MFD if possible.
There is one option that you can use that will enable you to create a slit in one side of the MFD dress. That option is using the Geometry Editor (new Beta) found under Tools other wise known as the Polygon Editor Tool to create a new narrow material zone going down the entire length of the skirt that you can then put the opacity to zero. I have done this with other outfits and it works fine especially if you are using shaders.
Hope that helps a bit.
