Does the "Hemet-nisut Hair and Accessories for Genesis 8 Female" download contain the props?
I only see the materials, but not the physical props.
JD
  • jdavison67jdavison67 Posts: 690
    edited September 2020
    OK.....it seems, that something is up with the file transfer....
    For some reason only the materials folder was transfered over to the Hemet-nisut folder...
    I had to find the content zip file and manually pull over the other files....
    Never had that happen before...
    Now I can actually load the hair props.
    JD
    Post edited by jdavison67 on
  • How did you install?
    I used the Install Manager.
    Then I had to find the zip file and move the files that didn't copy over to the root of the Hemet-nisut folder manually.
    The entire materials folder copied over without issues.
  • Please open a ticket to report this.
