Unreal Bridge, animations come out weird
I am trying to use the Daz to Unreal bridge, and I followed the tutorial that is on the shop page. Everything seems to work perfectly until I start to run around and jump (see attached screenshot). It looks like maybe the bones didnt map properly using automap, but I have no idea which ones to fix if so. Any ideas on why this might happen? I thouoght it might be because of the morph targets that I used, but I imported another version without morphs and it looks the same. This is using the stock ThirdPersonAnimBP, humanoid rig and Genesis8BaseSkeleton, the same as the tutorial used.
  • EllessarrEllessarr Posts: 1,390
    first rule "don't use automap" it will competely mess with the rig, just use the bridge to export the character it already come with a proper mapped skeleton without need do that.
    Hmm ok, I'll try that. The tutorial video used it so I figured I needed it.
  • Yea, the video needs a fix.  You might need to get a clean copy of the skeleton to fix it.  http://davidvodhanel.com/daz-to-unreal-getting-a-clean-copy-of-the-skeleton/
    We can - IF any insue mentioned up - just reinstal from DIM, right? ( i delete a pice or part froim my content - noob here) and download again the plugin :3
  • I think you should be able to just re-install the plugin to get a fresh copy.  If you intentionally made any changes to the skeleton or materials in the plugin, back them up first.
    I re-install, all fine now.
  • Anybody else having this HUGE PROBLEM with Daz Bridge?
    The faces gets destroyed.
    764 x 516 - 169K
  • The faces gets destroyed.
    Make sure you're setting the retarget source for the animation.  It's the second part on this page
    http://davidvodhanel.com/daz-to-unreal-animations/
