Does the "Hemet-nisut Hair and Accessories for Genesis 8 Female" download contain the props?
in The Commons
I only see the materials, but not the physical props.
JD
OK.....it seems, that something is up with the file transfer....
For some reason only the materials folder was transfered over to the Hemet-nisut folder...
I had to find the content zip file and manually pull over the other files....
Never had that happen before...
Now I can actually load the hair props.
JD
How did you install?
I used the Install Manager.
Then I had to find the zip file and move the files that didn't copy over to the root of the Hemet-nisut folder manually.
The entire materials folder copied over without issues.
Please open a ticket to report this.
