Problems with Blasphemy: poses and props for genesis 8 and infernal wings
Carola OCarola O Posts: 3,862
edited September 2020 in The Commons
Hello all,
I have a problem with [Blasphemy: poses and props] this pose set, or rather with one of the poses in it. Pose number 10, the one where the character crouches. It gives the same odd look for both male and female, with or without turning limits off (went into edit - preferences to try that, since there was no pop up prompting me to choose). When I made the render to show the problem, I put him on a primitive plane, and tried to make it show both above and below the plane, I forgot that it would be shadows from the plane that makes the toes and feet harder to see.
The worst part is that it is this pose that was the main reason I wanted the pose set in the first place, I do like several of the other poses too but this one was my favorite. It certainly don't look like this in the promos, or in the thumbnails, so I'm wondering what is wrong with it and if/how it can be fixed or if I need to make a ticket for it, but hopefully not. The fact that it is only this pose that is a problem makes me kinda confused, I also never had any problems with other pose set from Skyewolf before and quite like his/her pose sets.
Edited to add - also adding one of the promo images for this pose, and before someone mention it. I did try both with and without the wings but neither of them looks like in the promo
  • Are there separate poses for male and female? if so, try applying the "wrong" one in case they are mis-labelled.
  • For some reason it's not disabling limits on the Pelvis joint, and I don't know why because I used that very pose in a promo for my Ashan character and it was fine, so something's changed since then. I'm not sure why it isn't disabling that.
  • Carola OCarola O Posts: 3,862
    It is seperate, and I had tried that (probably should have written that too, sorry :) ) also, thanks for correcting the post, I admittingly forgot that I should have written out the pose set *hugs*
    If I disable the limit on the pelvis joint of my character, and than pose him.. would that work you think?.. I'll try that next time I'm in studio, it kinda crashed on me when I was in the process of working on a scene.. sooo I'm kinda annoyed right now lol. Not sure if it has been some update on it since you used it on Ashan and I bought it (a few days ago, during PA festival ), but perhaps something happened during that in that case?
    Post edited by Carola O on
    Yes, that's what I had to do and it worked fine. Is it prompting you to remove limits at all? I don't know why it isn't removing the limits for the pelvis though. I know they all worked properly when she made them. I tested them myself before she submitted the product :D It isn't turning it off for me either though which is the weird part and it isn't even prompting me to remove limits. I suspect this has to do with it being an h. pose, but I'm not sure. But, turning the pelvis limits off will fix it.
    I don't get a prompt at all, and I even tried to go into edit - preferences to change between all three of those choices, to see if that helped which it didn't. removing the limits from the pelvis did helpt though, so many thanks for that.. I honestly hadn't even thought of going into the figure itself to check before I came here to write my problem *sheepish smile*
    Nah, I expect it's a common problem and folks just don't come to ask, but since you have, there's a solution for everyone :D
