XTransfer Module 1- Genesis 3 to Genesis 8 Morph Converter (Commercial)
1272830323338
  • Had to download Firefox (as neither IE or Edge would upload the files) but I have now been able to upload the screenshots.
    945 x 386 - 41K
    433 x 222 - 17K
    300 x 283 - 13K
  • For your morph, is "auto-follow" checked under it's properties?
  • GRFK DSGN Unlimited wrote: "For your morph, is "auto-follow" checked under it's properties?"
    It was not.
    Unfortunately ticking it did not change the result - the eyelashes still show as per my screen shots above.
  • Zev0Zev0 Posts: 7,122
    edited September 2020
    Edited
    Post edited by Zev0 on
  • Well, you do have to save the morph after clicking the "auto-follow" box...
  • GRFK DSGN Unlimited wrote: "Well, you do have to save the morph after clicking the "auto-follow" box...".
    Well that explains why the auto-follow box was unticked when I next opened DazStudiosmiley.
    I have now resaved the morph (and that box now stays ticked when I reopen DazStudio).
    Unfortunately no change to the result - the eyelashes still show as per my screen shots above.
    Can I see the morphs being transferred please in this dialed up character. Also are you applying your transferred morph to a new Genesis 8 Base with lashes on or are you adding lashes after it is dialled up.
  • I have found a workaround for my problem.
    While looking at the store today I found  (www.daz3d.com/great-lashes-for-genesis-8-female-s) which I purchased.
    I then found I could use MeshGrabber (https://www.daz3d.com/mesh-grabber) to move these lashes up to where they should be, and once in the correct place they auto followed the eye movements correctly.
  • There's been no info about the G8 to G3 addon for quite a while now. Is it still in the works?
    The competing G8 to G3 product has been on sale several times but I keep avoiding buying it because I've already bought into this version, and don't really want 2 products that just do the same thing, but if the addon isn't likely to be coming over the horizon soon, I might as well just get the other one.
    Hi. Ye it's been seriously delayed. Our aim is to get it out before the year is over along side the inter gender module.
    Ok, thanks for giving some idea of the timescale.
  • lou_harperlou_harper Posts: 1,163
    edited October 2020
    I have used this product a lot and it usually works great. However, it doesn't work with Abel for G3 at all. (https://www.daz3d.com/abel-for-genesis-3-male) The body transforms some but the head not at all.
    Edit: never mind. I think there is an issue with Abel itself because his head doesn't look right in g3 either.
    Post edited by lou_harper on
  • GordigGordig Posts: 10,613
    Do you have the G3 aging morphs?
  • I have used this product a lot and it usually works great. However, it doesn't work with Abel for G3 at all. (https://www.daz3d.com/abel-for-genesis-3-male) The body transforms some but the head not at all.
    Please put the Viewport into Smooth Shaded draw style, or put some clothes on the figure.
    Sorry!
    I have the G8 one. I guess, I didn't think I needed it because I don't have G3 body morphs either, only G8 and the transfers work. If I get the G3 aging morphs, do I have to convert them too? And do I need the G3 head morps too?
    edited October 2020
    The script will auto convert any morphs the g3 character requires as long as they are present on g3. If any assets or required morphs are missing it will convert without them but wont look right. It will match exactly the same result on the g3 character in its current state.
    Gotcha! And thanks. :)
  • vozolgantvozolgant Posts: 207
    edited November 2020
    If I were to use this to transfer Lydia 7 https://www.daz3d.com/lydia-hd-for-victoria-7 to Genesis 8 Female, would there be any unforseen problems? I wouldn't transfer the HD, only the non-hd lydia.
    Post edited by vozolgant on
    Will work fineyes
  • kgrosserkgrosser Posts: 141
    Hooray! Just came along to check on these 2, keep looking forward to it!
    edited December 2020
    I've noticed since my update to 4.14, XTransfer crashes whenever it's going through the motions of running the favorited morph transfer process. I'm going to try it on my backed up 4.12.
    *update* It's crashing with 4.12 as well. I've never had this issue before. Seems to get as far as importing the G8 obj and then hangs on "reading asset" and then crash.
    This seems to be as far as it gets -
    2020-12-03 09:55:03.711 DEBUG: ------------------ Begin Processing Morphs ------------------
    2020-12-03 09:55:05.675 DEBUG: - Processing Main View List -
    2020-12-03 09:55:05.675 Processing Favorited Morphs
    2020-12-03 09:55:05.675 DEBUG: 14%
    2020-12-03 09:55:05.677 DEBUG: -- CTRL_LY_FR_Dwarf --
    2020-12-03 09:55:05.683 DEBUG: Saving XT LYFR Dwarf
    2020-12-03 09:55:05.683 DEBUG: sBasePath G:/My DAZ 3D/Studio/My Library
    2020-12-03 09:55:05.683 DEBUG: sVendor = XTTemp
    2020-12-03 09:55:05.683 DEBUG: sProduct = Lyoness/Fantasy_Race_DNA
    2020-12-03 09:55:05.685 DEBUG: sPropertyName XT_CTRL_LY_FR_Dwarf
    2020-12-03 09:55:05.944 Loaded image CTRL_LY_FR_Dwarf.png
    2020-12-03 09:55:05.946 Loaded image CTRL_LY_FR_Dwarf.png
    2020-12-03 09:55:05.978 Loaded image CTRL_LY_FR_Dwarf.png
    2020-12-03 09:55:05.986 Loaded image CTRL_LY_FR_Dwarf.png
    2020-12-03 09:55:06.101 DEBUG: Morph Successfully Saved
    2020-12-03 09:55:06.443 DEBUG: sOriginalPath G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 3/Female/Morphs/XTTemp/Lyoness/Fantasy_Race_DNA/XT_CTRL_LY_FR_Dwarf.dsf
    2020-12-03 09:55:06.444 DEBUG: G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA
    2020-12-03 09:55:06.447 DEBUG: sIconPathOriginal G:/DAZ 3D/My 3D Library/data/DAZ 3D/Genesis 3/Female/Morphs/Lyoness/Fantasy_Race_DNA/CTRL_LY_FR_Dwarf.png
    2020-12-03 09:55:06.452 DEBUG: sIconPathNew G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA/CTRL_LY_FR_Dwarf.png
    2020-12-03 09:55:06.454 DEBUG: Morph Card Copy Successful!
    2020-12-03 09:55:06.455 DEBUG: -- FBM_LY_FR_Dwarf --
    2020-12-03 09:55:06.462 DEBUG: Saving XT LYFR Dwarf Body
    2020-12-03 09:55:06.462 DEBUG: sBasePath G:/My DAZ 3D/Studio/My Library
    2020-12-03 09:55:06.462 DEBUG: sVendor = XTTemp
    2020-12-03 09:55:06.462 DEBUG: sProduct = Lyoness/Fantasy_Race_DNA
    2020-12-03 09:55:06.468 DEBUG: sPropertyName XT_FBM_LY_FR_Dwarf
    2020-12-03 09:55:06.718 Loaded image FBM_LY_FR_Dwarf.png
    2020-12-03 09:55:06.720 Loaded image FBM_LY_FR_Dwarf.png
    2020-12-03 09:55:06.753 Loaded image FBM_LY_FR_Dwarf.png
    2020-12-03 09:55:06.754 Loaded image FBM_LY_FR_Dwarf.png
    2020-12-03 09:55:07.791 DEBUG: Morph Successfully Saved
    2020-12-03 09:55:08.094 DEBUG: sOriginalPath G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 3/Female/Morphs/XTTemp/Lyoness/Fantasy_Race_DNA/XT_FBM_LY_FR_Dwarf.dsf
    2020-12-03 09:55:08.100 DEBUG: G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA
    2020-12-03 09:55:08.117 DEBUG: sIconPathOriginal G:/DAZ 3D/My 3D Library/data/DAZ 3D/Genesis 3/Female/Morphs/Lyoness/Fantasy_Race_DNA/FBM_LY_FR_Dwarf.png
    2020-12-03 09:55:08.117 DEBUG: sIconPathNew G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA/FBM_LY_FR_Dwarf.png
    2020-12-03 09:55:08.119 DEBUG: Morph Card Copy Successful!
    2020-12-03 09:55:08.124 DEBUG: -- FHM_LY_FR_Dwarf --
    2020-12-03 09:55:08.136 DEBUG: Saving XT LYFR Dwarf Head
    2020-12-03 09:55:08.136 DEBUG: sBasePath G:/My DAZ 3D/Studio/My Library
    2020-12-03 09:55:08.136 DEBUG: sVendor = XTTemp
    2020-12-03 09:55:08.136 DEBUG: sProduct = Lyoness/Fantasy_Race_DNA
    2020-12-03 09:55:08.137 DEBUG: sPropertyName XT_FHM_LY_FR_Dwarf
    2020-12-03 09:55:08.410 Loaded image FHM_LY_FR_Dwarf.png
    2020-12-03 09:55:08.411 Loaded image FHM_LY_FR_Dwarf.png
    2020-12-03 09:55:09.002 DEBUG: Morph Successfully Saved
    2020-12-03 09:55:09.324 DEBUG: sOriginalPath G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 3/Female/Morphs/XTTemp/Lyoness/Fantasy_Race_DNA/XT_FHM_LY_FR_Dwarf.dsf
    2020-12-03 09:55:09.331 DEBUG: G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA
    2020-12-03 09:55:09.342 DEBUG: sIconPathOriginal G:/DAZ 3D/My 3D Library/data/DAZ 3D/Genesis 3/Female/Morphs/Lyoness/Fantasy_Race_DNA/FHM_LY_FR_Dwarf.png
    2020-12-03 09:55:09.342 DEBUG: sIconPathNew G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA/FHM_LY_FR_Dwarf.png
    2020-12-03 09:55:09.344 DEBUG: Morph Card Copy Successful!
    2020-12-03 09:55:09.348 DEBUG: Finished Saving Main Morphs in 0 minutes 04 seconds
    2020-12-03 09:55:09.355 DEBUG: - Processing Sub View List -
    2020-12-03 09:55:09.361 Processing Linked Morphs
    2020-12-03 09:55:09.361 DEBUG: 28%
    2020-12-03 09:55:09.361 DEBUG: Finished Saving Linked Morphs in 0 minutes 00 seconds
    2020-12-03 09:55:09.361 DEBUG: 42%
    2020-12-03 09:55:09.361 DEBUG: Repairing Parent and Vertex Count
    2020-12-03 09:55:09.366 Repairing Parent and Vertex Count
    2020-12-03 09:55:10.346 DEBUG: Finished Editing Morph Files in 0 minutes 01 seconds
    2020-12-03 09:55:10.346 DEBUG: Repairing AssetIDs
    2020-12-03 09:55:10.368 Repairing AssetIDs
    2020-12-03 09:55:10.368 DEBUG: 56%
    2020-12-03 09:55:10.411 DEBUG: Fixing AssetID G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA/XT_CTRL_LY_FR_Dwarf.dsf
    2020-12-03 09:55:10.422 DEBUG: Fixing AssetID G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA/XT_FHM_LY_FR_Dwarf.dsf
    2020-12-03 09:55:10.613 DEBUG: Fixing AssetID G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA/XT_FBM_LY_FR_Dwarf.dsf
    2020-12-03 09:55:11.046 DEBUG: Fixing AssetID G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA/XT_FHM_LY_FR_Dwarf.dsf
    2020-12-03 09:55:11.227 DEBUG: Fixing AssetID G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA/XT_CTRL_LY_FR_Dwarf.dsf
    2020-12-03 09:55:11.334 DEBUG: Fixing AssetID G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA/XT_FBM_LY_FR_Dwarf.dsf
    2020-12-03 09:55:11.618 DEBUG: Fixing AssetID G:/My DAZ 3D/Studio/My Library/data/DAZ 3D/Genesis 8/Female/Morphs/XTransfer/Lyoness/Fantasy_Race_DNA/XT_CTRL_LY_FR_Dwarf.dsf
    2020-12-03 09:55:11.683 DEBUG: Finished Repairing Asset IDs in 0 minutes 01 seconds
    2020-12-03 09:55:11.683 DEBUG: 71%
    2020-12-03 09:55:11.684 Updating Morph Deltas
    2020-12-03 09:55:11.685 DEBUG: Transferring Morph Deltas
    2020-12-03 09:55:11.703 Exporting File...
    2020-12-03 09:55:11.751 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-03 09:55:11.751 Loaded file: pJCMThighSide_85_R.dsf
    2020-12-03 09:55:11.755 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-03 09:55:11.755 Loaded file: pJCMThighSide_85_L.dsf
    2020-12-03 09:55:11.759 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-03 09:55:11.759 Loaded file: pJCMShldrDown_75_R.dsf
    2020-12-03 09:55:11.762 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-03 09:55:11.762 Loaded file: pJCMShldrDown_75_L.dsf
    2020-12-03 09:55:11.819 Saving Geometry...
    2020-12-03 09:55:11.957 File exported in: 254.633 ms
    2020-12-03 09:55:11.959 Exported file: G:\DAZ 3D\Temp\XTransfer\XTG3Base.obj
    2020-12-03 09:55:12.103 Exporting File...
    2020-12-03 09:55:12.183 Saving Geometry...
    2020-12-03 09:55:12.284 File exported in: 181.875 ms
    2020-12-03 09:55:12.285 Exported file: G:\DAZ 3D\Temp\XTransfer\XT_FBM_LY_FR_Dwarf.obj
    2020-12-03 09:55:12.468 DEBUG: Needs Repair: true
    2020-12-03 09:55:12.468 DEBUG: bRepairBones true
    2020-12-03 09:55:12.655 DEBUG: Creating Donor
    2020-12-03 09:55:12.778 WARNING: Empty weight map passed to DzWeightMap::normalizeMaps().
    2020-12-03 09:55:13.047 Exporting File...
    2020-12-03 09:55:13.151 Saving Geometry...
    2020-12-03 09:55:13.246 File exported in: 198.72 ms
    2020-12-03 09:55:13.247 Exported file: G:\DAZ 3D\Temp\XTransfer\XT_FHM_LY_FR_Dwarf.obj
    2020-12-03 09:55:13.396 DEBUG: Needs Repair: false
    2020-12-03 09:55:13.396 DEBUG: bRepairBones true
    2020-12-03 09:55:13.664 Importing File...
    2020-12-03 09:55:13.709 Reading XTG3Base.obj
    2020-12-03 09:55:13.759 Geometry Imported: XTG3Base.obj
    2020-12-03 09:55:13.842 File imported in: 178.502 ms
    2020-12-03 09:55:14.265 Imported file: G:\DAZ 3D\Temp\XTransfer\XTG3Base.obj
    2020-12-03 09:55:14.522 Loading Morph: XT_FBM_LY_FR_Dwarf.obj
    2020-12-03 09:55:14.915 Reading XT_FBM_LY_FR_Dwarf.obj
    2020-12-03 09:55:14.937 Geometry Imported: XT_FBM_LY_FR_Dwarf.obj
    2020-12-03 09:55:14.937 Creating morph for XTG3Base...
    2020-12-03 09:55:14.938 Morph contains 11384 deltas
    2020-12-03 09:55:15.069 Loading Morph: XT_FHM_LY_FR_Dwarf.obj
    2020-12-03 09:55:15.442 Reading XT_FHM_LY_FR_Dwarf.obj
    2020-12-03 09:55:15.463 Geometry Imported: XT_FHM_LY_FR_Dwarf.obj
    2020-12-03 09:55:15.463 Creating morph for XTG3Base...
    2020-12-03 09:55:15.463 Morph contains 6251 deltas
    2020-12-03 09:55:15.496 DEBUG:
    Loading morph XT_FBM_LY_FR_Dwarf...
    Created morph successfully.
    Loading morph XT_FHM_LY_FR_Dwarf...
    But it crashes before it says "finished" and when I try to use the morphs they go all wank-a-doo and blow up the figure when I use them.
    Post edited by MelissaGT on
    How heavy is your Genesis 8 Female in terms of morphs? Maybe strip out the data folder of none essential packages when doing a transfer to see if that helps, then copy them back.
    I don't think it's any heavier than the vast majority of users. My base G8F takes about 30sec to load with a 8-core processor and 32GB of RAM.
    AH ok...
    Zev0 said:
    AH ok...
    I have way less male content...I'll try running some transfers for G3M to G8M and see if that makes a difference. I'll also try to uninstall and reinstall the script.
    I'm not sure what would have changed...I successfully used the script in the past and it's never crashed before. I did recently reinstall my operating system, but that didn't effect Daz files...all that stuff is on another drive that wasn't touched.
    I tried uninstalling and reinstalling via DIM and then running a male morph through and still crash:
    txt
    txt
    Daz Crash Log - XTransfer.txt
    68K
  • ramastersramasters Posts: 91
    I'm having an issue that it's crashiing once I try to load a G8M (after I export a G3M morph). I'm just exporting the morphs of Kenji and Sasori, so not a lot of morphs. 4.14
    Post edited by ramasters on
  • plaul2002plaul2002 Posts: 128
    Stupid quesiton but did this product used to transfer custom G3 to G8?  I went to use it today and all it wants to do is transfer base V7 to G8.  That's pointless.  I thought this used ot transfer customs to G8?  Did I miss something?
    Post edited by plaul2002 on
    So help me understand this product.  I work on a custom G3 charcter and use G3 morphs, maybe 10s of them.  I now want to convert to G8.  I open daz drop in a base G3 and am supposed to heart all the morphs I used on the custom character?  Then run the script and those morphs will the be applied to the G8?
    I would have swore on my life this product used to be much easier to use...am I out of my mind here? This seems to be false advertising a bit. Seems more like a Morph conversion not a character conversion.
