looking for some raggedy clothing
WillowRaven
in The Commons
It's easy to find a bikini in tatters or scratched-up armour, but finding everyday clothing in rags, as if someone has been through a fight, say pajama pants and a t-shirt, is near impossible ... y'all know of any?
https://www.daz3d.com/dforce-torn-clothes-for-genesis-8-males
https://www.daz3d.com/dforce-torn-clothes-for-genesis-8-females
Thanks :) These are perfect :)
https://www.daz3d.com/ptf-grungy-threads
you also have the option to use this product for using on any outfit im in the middle of a render using it will post when i have it ;)
Grungy Threads is great! I can absolutely recommend it.
That would be amazing if it wasn't iray-only :(
You can manually load the opacity maps in 3delight without much issue. There used to be a similar shader pack specifically for 3delight called rag-erator, but the maps are much smaller and may not work that well with modern textures (and it seems to have vanished from the store).
Still, Deviney has this pack, which should allow you to do much of what you need. Also, I am pretty sure if you look for "zombie" or "survivor" in the store you will find a few items that may fit your criteria.
Brill renders really shows of how to use the shaders correctly heres my attempt a bit cleaner version than your durty and blood spattered ;)
