• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
2.83 Bake Displacement & Normals High Poly -> Low Poly
algovincianalgovincian Posts: 2,670
September 2020 in Blender Discussion
I'm currently running Blender 2.83, and am looking for a way to bake both displacement & normals from an existing high poly object to an existing low poly object. I was able to do so in previous versions of Blender, but it seems to now require a multi-resolution object (as opposed to 2 separate existing objs).
If anyone could shed some light on how I'm being an idiot, it would be much appreciated!
- Greg
  • Krys KryngleKrys Kryngle Posts: 315
    September 2020
    It's not very straightforward, but I figured it out from this video and probably some addtional searches.  Another tutorial said to bake to .exr files to avoid lost details.  Try it and let us know if you get stuck.  Delete the eyes, teeth, and fingernails, you don't need them.  Use Diffeomorphic's combine like materials, then make sure you have the image texture node in each material to bake (like I said, not very straighforward).
  • algovincianalgovincian Posts: 2,670
    September 2020
    Thanks for the link and taking the time to respond. Unfortunately, this method still requires a multires object, and thus shrinkwrapping to produce the high poly rather than using an existing high poly. This is exactly what I was trying to avoid.
    Did some more digging:
    https://devtalk.blender.org/t/how-can-we-bake-displacement-on-2-8/7711/8
    It seems as though this is not possible in Cycles. Since Blender Internal was removed, I think I'm SOL at the moment. I'll keep looking for a way in 2.83 and if I come up with a solution, I'll be sure to post.
    A frustrating step backward, but in the meantime, I'll just use 2.79 or another piece of software all together. Thanks again.
    - Greg
  • MendomanMendoman Posts: 404
    September 2020
    Hmmm, can't you just add multiresolution modifier for your high poly mesh, and just use that to bake maps? I think that's how I baked my displacement maps, and it worked quite ok.
    September 2020
    Thanks for taking the time to respond, but I'm not sure I understand what your saying.
    I'm not sculpting the high resolution mesh in Blender - it already exists. Like I said, both the low-poly and high-poly meshes aleady exist and are imported.
    I've tried adding a multires modifier to the low-poly, sub-dividing within the multires object, and then using the reshape option to try and re-create the existing high-poly within the multires object, but I haven't been able to get it to work.
    - Greg
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
