• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Switching "Track to" on a camera
brainmuffinbrainmuffin Posts: 1,267
August 2020 in Blender Discussion
I've tried several different ways and none of them have worked so far. I want to track an object with the camera until it crosses paths with another one, then switch and follow the second. I've tried changing the "track to" in a keyframe, but that value doesn't seem to be update able and the change affects the whole animation. I've also tried adding a second "Track to" constraint to the camera, pointing at the second object, and adjusting the Influence values at the cross point. I see the keyframe in the animation, but again the values stay changed for the whole thing. While I know I can do to renderings and make the change in post, I'm trying to do this all in Blender. Anyone have any other ideas?
  • skinklizzardskinklizzard Posts: 218
    August 2020
    maybe create an invisible object that follows the first object to the shift point and then follows the second object, and track to that instead, not sure how viable that would be in your case though.
  • nicsttnicstt Posts: 11,715
    August 2020
    I use constraints a lot, but tracking the camera isn't something I've done recently (if ever?).
    ... But that's where it is.
    367 x 707 - 29K
    355 x 582 - 40K
  • andya_b341b7c5f5andya_b341b7c5f5 Posts: 694
    August 2020
    Two 'Track To' constraints, one targetting each object, is the way to go I think.  Then, although I imagine keyframing the influence value would work, why not just keyframe the enabled/disabled state of each constraint?
    A quick test - green cube moves to the right then back to the left passing in front of the blue cube.  Blue cube starts to move up when the green cube crosses in front of it at fram 71.  Camera tracks green cube to frame 71, then the blue cube, with 'Track To' for green cube disabled at frame 71 and 'Track To' for blue cube toggled from disabled to enabled at that point.  The camera is stationary to simplify things.
    Probably the constraint on the blue cube takes over in any case when it becomes enabled, but to ensure no effect by the 'Track To' on the green cube I disabled it.
    1915 x 1019 - 258K
    1915 x 1021 - 266K
  • brainmuffinbrainmuffin Posts: 1,267
    August 2020
    Hmm...this is an interesting idea. Techincally, the camera is actually following an empty that is attached to the drone. It is a square slighly larger than the drone. I'll have to experiment with that.
    August 2020
    I'll give this a try as well. I also need to make sure the first keyframe is setting the values properly. I think that might be why a change effects the entire animation.
    August 2020
    I am still trying to do this. Nothing has worked so far.
  • CinusCinus Posts: 118
    August 2020 edited August 2020
    @brainmuffin Use two cameras placed at the same location. Camera one tracking object a and camera two tracking object b. Switch cameras when the objects cross.
    https://www.youtube.com/watch?v=Q8acK_aa4jQ
    Post edited by Cinus on August 2020
    August 2020
    That will probably be more jarring than how I have the camera switching now. An 8 year old Blender tutorial.... what's the likelihood it doesn't work anymore. I've had zero luck with videos more than 6 months old.
  • margravemargrave Posts: 1,822
    August 2020
    I think the difficult you're facing really just emphasizes some things need to be done by hand. Nonetheless, I found a solution:
    Create an empty with two "Child Of" constraints. Turn off everything in the constraints but the location and animate the influences so it's smoothly "handed off" between the two objects. Then put a Damped Track constraint on your camera with the empty as the target and "-Z" as the tracking axis.
    Just tried it, works 100%.
    However, it does make the camera go topsy-turvy as it tries to follow the objects. I couldn't figure that part out. If you can't, you might just need to keyframe the camera's rotation. so it remains upright.
    August 2020
    Yeah, the "topsy-turvy" camera is what I'm combatting, though I have it smoother than it has been. You may be correct though. I may need to keyframe values for rotation when it get close to the handoff point.
    September 2020 edited September 2020
    You are right @brainmuffin, the solution I proposed produces a rather jarring effect.
    @skinlizard's suggested solution works well. Curious to know what issues you ran into when you tried that.
    Post edited by Cinus on September 2020
    September 2020
    Haven't tried it yet as Blender stopped rendering stills for that scene. I figured out that problem. Now my poor Linux box is out of RAM. I have an 8GB upgrade on the way.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
