can not load LAMH assets!!!
Leo ChenLeo Chen Posts: 697
Two bad .duf can not load LAMH assets!
How come these two bad .duf have same problem with the LAMH?
  • Richard HaseltineRichard Haseltine Posts: 110,478
    If you are trying to apply the hair to the tiger you need the tiger selected, as far as I know.
  • Leo ChenLeo Chen Posts: 697
    Thank you,Richard Haseltine.
    I used "LAMH - White Tiger.duf" instead of "White Tiger.duf".
    The attached image was rendered before the scene file turned bad.
    PS: I needed to re-adjust the scene that ....
    1080 x 1920 - 883K
    Is there anyway to fix these two bad .duf ?
    It depends on what the error is, and where. I haven't seen a scene go bad in the Look at My Hair section (as far as I know) but someone did have a scene fail in the data for the Octane plugin and I couldn't see any way to recover the data after that section - which was the part that stored the posing. You might try posting in the main Look at My hair thread - Kendall or Alessandro may be able to help.
